first acura Ls-vtec
Old Jan 7, 2010 | 12:03 PM
SPEEDY-G-TypeR's Avatar
Icon6 first acura Ls-vtec
this is my first acura integra and opt. for ls vtec /boosted the swap was nice but im running in to some stuff. do i need a gsr oil pump or water pump . and what C/R should i run if boosted I found a kit on line
(4) Eagle H Beam Rods
(4) JE/SRP Pistons-Wrist Pins and Locks
(1) Complete Set of JE File Fit Rings
(1) Eagle 4340 Forged Steel Racing Crankshaft
Full Set of Main and Rod Bearings
Assembly Lube.
the head is fully built and tranny is set up nice could i get a lil more help . im a noob ...in the honda world ...
Old Jan 7, 2010 | 08:51 PM
88Hatchy's Avatar
Default Re: first acura Ls-vtec
You don't need an after market crankshaft. You are better off using OEm bearings. A good compression ratio for a turbo Honda is around 9.5:1. Just read around in the Forced Induction forum to get more ideas.
Old Jan 8, 2010 | 10:19 AM
I WANT TO CHANGE THE CRANK I SPUN THE ROD BER. AND I WANT TO TRY TO MAKE 500-600Hp THE CARS GOT 200,000 + MILES on it ...
Old Jan 8, 2010 | 07:56 PM
91h22cb7lx's Avatar
with those hp goals, you might wanna save the money from the crank and get better rods/pistons
Old Jan 8, 2010 | 08:09 PM
SoTexDC2's Avatar
If your crank is damaged, I suggest you get another OEM crank.
Old Jan 10, 2010 | 11:29 AM
so wuz so bad about the aftermarket crank and so good about oem
Old Jan 13, 2010 | 11:06 AM
milkmanLCA's Avatar
it gets the job done and is inexpensive
Old Jan 13, 2010 | 12:06 PM
ok .... and what size injectors should i run ..
Old Jan 13, 2010 | 12:36 PM
SoTexDC2's Avatar
It's up to you what injectors you run.
You need to visit the Forced Induction forum and do some research. Nobody is going to spoon feed you everything.
Old Feb 1, 2010 | 05:49 PM
nh-egcoupe's Avatar
dont waste cash on crank the stock crank can handle crazy numembers of hp just go for all good parts type r oil and water pump acl race bearings arp head studs
go on google type in ls vtec a guy has a great write up
rejuvinile
Engine Machining & Assembly
14
Mar 4, 2016 07:25 AM
mx125cc
May 31, 2013 03:55 PM
kyosoeg6
11
May 16, 2011 06:39 PM
GoldLudeRay
Sep 13, 2008 03:51 AM
loudassVTEC
Jun 30, 2006 03:45 AM
