eg tech manual? will it work for 01 crv?
Old Jan 7, 2010 | 11:21 AM
tougetuned_ef's Avatar
Default eg tech manual? will it work for 01 crv?
i have an 01' crv and im about to do a new t-belt, clutch, and valve lash. it just hit 80k so its time to do it. i have an eg/delsol tech manual from my buddy who used to be a tech at out local honda dealer. my question is can i follow the same step/procedures as it says for a b16 on my b20. tourqe specs, valve lash steps? if some one has a ek tech manual or ls integra manual i can compre step to that would help big time!
Old Jan 7, 2010 | 02:17 PM
delsolproblems's Avatar
Default Re: eg tech manual? will it work for 01 crv?
They are about the same procedures. With a little experience and common sense you should be fine. The clearances for your motor are .003-.005 on the intake and .006-.008 on the exhaust. Make sure the motor is as cold as possible when setting valve lash.
Torque in ft/lbs unless otherwise stated-
*Pressure plate bolts: 19
*Lower Rear Engine to Transaxle Bolts: 14 x 1.5mm- 61
12 x 1.25mm- 47
*Upper Transaxle to Engine Bolts: 47
*Right Upper Transaxle Mount: Mount Bolt and Nuts- 47
Engine Bracket to Mount Through-bolt- 54
*Right Front Transaxle Mount: Mount to Transaxle- 47
Mount Bracket to Body- 33
*Clutch Cover Bolts: 6 x 10mm Bolts 108 INCH-POUNDS
12 x 1.25mm Bolts- 22
*Timing Cover Bolts: 86 INCH-POUNDS
*Valve Cover Bolts: 86 INCH-POUNDS
Good Luck
Old Jan 9, 2010 | 02:58 PM
thank you much! also nice avatar! me and my girl are bird lovers also. the motor is going to be pulled completely so it will def be cold. i figured it would be easier to do it all at once with the motor out.
Old Jan 9, 2010 | 05:32 PM
For sure. Have some all purpose import grease on hand for little things like where the slave cylinder presses the release fork. Anything that gets greased inside the clutch cavity only gets a thin layer so grease doesn't fling onto the clutch. If you want to grease a part that comes pre-oiled, such as some bearings, clean the oil off first with alcohol because the oil may not mix with the grease.
Squeak is my Sun Conure. I found a wonderful breeder while I was living in northern Ohio who was waiting for her latest clutch to hatch. She emailed me pics from when he first hatched with no feathers and closed eyes up to when he was ready to take home. That was almost exactly ten years ago. They are said to live around 30 years. When I met my fiance in an mmorpg and decided to move to Oregon with her, Squeak drove with us all the way across the country. He has since driven to OH and back to OR again and loves our road trips in the Del Sol. He crawls under the blanket and sleeps with us in hotels along the way. He loves fluffing up his feathers and rubbing his back and head up and down against our cheeks when he sits on our shoulders. He says his name, "I love you", "peanut". He'll ask to "hop up" when he wants to be with us and asks to "go poop" so he doesn't go on our shoulders. I could go on and on. He's the most wonderful creature we've ever known
Old Jan 9, 2010 | 08:00 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
What about the 1st Gen CR-V manual? Would this help? http://hondatech.info/downloads/Auto/Manuals/CR-V/
Old Jan 10, 2010 | 12:29 PM
My GF wants me to say how much we like your avatar as well.
Old Jan 12, 2010 | 02:23 PM
thanks. my fiance has a sun conure as well at her moms and we have to parakeets at our apt. her conure is 13 and knows step up and kitty cat, stuff like that. i accually found my parakeet on the roof of my van! me and a landscaper cought him and i went out and bought another to give him a friend.
Old Jan 12, 2010 | 02:25 PM
thank you thats perfect. i just printed the pages i needed.
JoeBull
Jul 16, 2010 10:09 PM
hu
Jul 25, 2006 09:57 PM
Ruby Civic
Mar 1, 2003 04:46 PM
B18aTegra
Aug 20, 2002 10:42 PM
