Okay HT I need Some Help
Old Jan 7, 2010 | 11:02 AM
sakasaku's Avatar
Default Okay HT I need Some Help
Ive been Reading in to making B swap Harness For An Ef and I just cant Find and good Write up that tells me what i need to actually do, Yes i have researched for 3 weeks now so if you know any post em pls!
Btw it a obd1 ls swapping and i am making the harness can do it just need the material thanks ,Sakasaku
Old Jan 7, 2010 | 11:23 AM
sakasaku's Avatar
Default Re: Okay HT I need Some Help
Old Jan 7, 2010 | 11:29 AM
masterEF's Avatar
heres one http://www.crxresource.org/modules.p...rticle&sid=134
its on a rex but im pretty sure it identical to the ef
Old Jan 7, 2010 | 02:39 PM
sakasaku's Avatar
need more info on what i need to do to make the harness work
Old Jan 7, 2010 | 03:01 PM
masterEF's Avatar
do you still have the original engine (d15 dpfi) cuz i heard if you already have the mpfi its just plug and play and you just need to hook up the vtec and a obdo-obd1 jumper
Old Jan 7, 2010 | 06:32 PM
sakasaku's Avatar
you have to convert the DPFI Harness to 0BD1 MPFI with resistor Box delete just need the how and what wire to change and add in
Old Jan 8, 2010 | 10:52 AM
sakasaku's Avatar
Old Jan 8, 2010 | 01:09 PM
D16SiHatch's Avatar
there are many writeups out there for, this is just one of them
http://hondaswap.com/swap-articles/d...writeup-49557/
it will tell you how and what you need to add in order to run mpfi. once you've done that you'll need an obd1 ecu, obd1 dizzy, obd0 to obd1 jumper, and a 4 wire o2 sensor. if you keep the obd1 injectors then delete the resistor box. if you use obd0 injectors, then you can leave the box.
Old Jan 9, 2010 | 11:15 AM
sakasaku's Avatar
i have all that i have everything
Old Jan 9, 2010 | 11:32 AM
crx_si-r's Avatar
then, what else are you looking for?
if you dont know what your doing, contact ryan@rywire.com send him your harness and plugs and he will make you a plug n play set up
1BADEF
Sep 12, 2008 01:49 AM
KyleVA
Jan 1, 2007 11:37 AM
Bseries!EF!hatch
May 19, 2006 08:24 AM
bustedEF
Oct 28, 2005 12:12 AM
