slow idle
Check the grounds, the condition of the plugs and the spark at all four wires. A weak spark is susceptible to system power drains. After that go through the motions. Since the spark isn't quite as strong when accessories are on at idle, any problems decreasing combustion will be more obvious at that time.
Get a regular cap unless you have installed an external ignition coil. The wires are the parts you want to put a little extra money into. Most agree the best are NGK wires available through Summit. They have high quality connectors that last a long time.
Lewsears
Mar 20, 2010 09:25 AM
zanglezonker
Dec 9, 2008 04:17 AM
