radiator hose's staying cold.
Old Jan 6, 2010 | 03:56 PM
pliskin679's Avatar
Default radiator hose's staying cold.
so i bought a 98 GS from someone and the car runs pretty good, once i drove it for almost 1.5 hours and got out of the car to see if its leaking oil and what not, and i felt the hose's and theres no pressure, and they are cold. the car is staying where it needs to be temprature wise also... so its not over heating... and it has full fluid... wtf? lol
Old Jan 6, 2010 | 04:01 PM
90_EX_Civic's Avatar
Default Re: radiator hose's staying cold.
might be a thermostat. are both hose's cold or just the top? also are you running just water or anti freeze/mix????
also from were you are at, pretty sure right now it'll be hard to over heat your car, even running for 1.5hrs. what is it like out side? 7*????
integra_101's Avatar
Dont take my word.
Might be the rad
Old Jan 6, 2010 | 04:07 PM
pliskin679's Avatar
yea, its fking cold lol. it hit -5 with windchill :x ill check it out more tomorrow
Old Jan 6, 2010 | 04:09 PM
pliskin679's Avatar
but the top hose gets slightly warm, but the bottem is ice cold its a thin full size rad.
pliskin679's Avatar
i personally like thick half rads... lol
Old Jan 6, 2010 | 04:12 PM
fasthatch95's Avatar
i took out my thermostat on my si cuz it was bad, and never put a new one back in it,and it does the same thing wth 50/50 and itz still cold weather.
Old Jan 6, 2010 | 04:33 PM
follie gatts's Avatar
if the thermostat is stuck open, both hoses will be the same temperature--warm, hot if you hold on to them for a few seconds.
it could be stuck closed as well, but i've never experienced that issue.
you could drain the radiator and put a hose into the top to see how quickly it drains.
smokeyjpn221
Jan 27, 2010 02:28 AM
1991hb
Mar 21, 2007 07:31 PM
Tad
Oct 20, 2006 02:23 PM
SleepyHF
Apr 7, 2004 06:59 PM
