civic electrical problem
Old Jan 6, 2010 | 03:04 PM
jolecai23's Avatar
New User
Default civic electrical problem
90 civic, 1.5 engine, mt, failed to crank, turned switch to on and push started to get home. at next attempt all electrical systems on car failed when switched to start. ignition switch failed test and was replaced, now switching to on kills all electrical systems on car. battery and connections all clean, ecm ground clean, im stymied, any help would be appreciated, thanks
Old Jan 6, 2010 | 03:08 PM
dohc4life's Avatar
Default Re: civic electrical problem
check your alternator sylenoid fuse i think its number 8 in your under dash fuse box, check the wires to your switch you could have a short check your grounds check the wire to your starter check your wires from your battery cable in your under hood fuse box, im pretty sure its the alternator sylenoid fuse though
Old Jan 6, 2010 | 03:19 PM
jolecai23's Avatar
New User
the alternator solenoid valve fuse is good. cables to fuse box under hood are good too. could the failing ignition switch have fried the ecm? seems that if that had happened i wouldnt have been able to drive the car after push starting it.
Old Jan 6, 2010 | 03:35 PM
dohc4life's Avatar
i would say check your starter, did you just buy the car maybe theres a kill switch you dont know about, check all connections at your ecu
Old Jan 6, 2010 | 03:37 PM
dohc4life's Avatar
also check your ecu for check engine lights when the key is on, is there a key or just push button start
Old Jan 7, 2010 | 07:28 AM
jolecai23's Avatar
New User
when you turn on the key all electrical systems on the car go dead
Old Jan 8, 2010 | 09:19 AM
jolecai23's Avatar
New User
is it possible that im the only person who has experienced this particular type of failure?
Taylor1976
May 13, 2018 04:05 PM
hondaEg_808
26
Jan 19, 2015 03:27 PM
jdm206
11
Sep 17, 2007 11:59 AM
90Integra
Aug 6, 2006 01:01 PM
ITRbroham
Nov 4, 2004 06:30 AM
