mpfi swap help?!
Old Jan 6, 2010 | 02:35 PM
dohc4life's Avatar
Default mpfi swap help?!
okay 91 civic hatch back dx 5 speed pr4 ecu from a 91 ls, i havent quite finished the swap just because i wanna read up on some stuff this is the 5th or 6th mpfi swap im done but never encountered this, anyways y8 manifold and tb dpfi harness with obd1 mpfi wiring, and i have an msd igniton cap rotor and external coil, but its the dpfi dizzy now im not sure if its possible but with the msd igniton would i still have to add wires to my ecu for the dizzy ive never done it this way, is there anyway i could just add wires to my dpfi dizzy then to the ecu and make it mpfi? it would be alot easier then looking for a si dizzy
Old Jan 6, 2010 | 03:59 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: mpfi swap help?!
Say whhhaaaatttt?????
What you say is mumbo-jumbo.
Either way, you can't do OBD-1 with that OBD-0 ECU. Ask yourself this question: Does the MSD box have a reluctor ring in it with a hall effect switch? (that is a big N-O!) You need to use the stock distributor and don't waste your time with the MSD ignition. You do NOT
Old Jan 6, 2010 | 04:11 PM
Eighty-Nyne's Avatar
What?
And no, the DPFI td-01 distributor doesn't have a CYP, Cylinder position sensor.
You're going to need a td-02 Mpfi distributor.
People have tried modifying the DPFI dizzy, but it will always throw a code 9...and go into limp mode whenever it decides it wants to.
Also, the stock coil is good for like 400hp....I don't know why you have a MSD external coil. Sell that and make some money.
ktay1990
Apr 20, 2014 09:57 AM
Evan125
Nov 14, 2013 07:15 PM
whiteboy03si
Feb 21, 2007 10:01 PM
drSquish
Mar 13, 2006 06:11 AM
macutty
Jan 13, 2006 08:33 AM
