Del Sol Idle Problem - Update -
Old Sep 3, 2002 | 11:45 PM
B-Series Sol's Avatar
Default Del Sol Idle Problem - Update -
You may have noticed me asking ton's of questions about where/how to get a new throttle body. To make a long story short, i tried milling out my stock B16a3 TB, with disasterous effects (3000rpm idle). I tried fixing it by adjusting the idle-air screw and the TPS, but it only ran worse.
The other day my tabs expired... An emissions test was required... Emissions Testers would not take me because my car idled @ 3000rpm.
Today, a Throttle body finally came in from a 95 Integra LS. The TB fit perfectly, all is fine, except the Integra TB has some extra clamps that are benine.
I clenched my teeth as I started it up, and wheeww... it idle'd normally. After I drove it I realized how poorly my milled Throttle body responded. All is well now.
Thanks for those of you who helped me w/ TB questions.. Honda-Tech Rules all!
Old Sep 3, 2002 | 11:51 PM
97hb's Avatar
Default Re: Del Sol Idle Problem - Update - (B-Series Sol)
Good job man
Don't you just love it when things work right
Old Sep 3, 2002 | 11:56 PM
Default Re: Del Sol Idle Problem - Update - (97hb)
well, the other day i was about to ditch my car in the river, but now I just might keep it
skuded
Nov 12, 2010 02:15 PM
95_red_dc
Sep 11, 2006 09:47 PM
Green B16Sol
Aug 30, 2006 05:15 PM
ShortbusEK
12
Apr 8, 2002 02:58 PM
