Suspension & Brakes Theory, alignment, spring rates....
rear caliper itr???
Old Jan 6, 2010 | 10:42 AM
95itr-ej2's Avatar
Default rear caliper itr???
Hi everyone,
I have a ej2 coupe runnin 97 itr breaks all round, problem is when i pull the hand break the rear right hand side caliper wont break no matter how hard I pull,
The cable are good and i can see the handbreak arm on the caliper moving,
I just need to know is this costly to fix???
Are all rear calipers the same or does it have to be off of itr.
I need new front breake discs, what brand are best to use???
Old Jan 6, 2010 | 11:15 AM
kommon_sense's Avatar
Default Re: rear caliper itr???
What happens when you press the brake pedal? Does the caliper lock up the wheel then?
Also, how are you testing this? I assume the car is on jackstands when you pull the ebrake...
Old Jan 6, 2010 | 03:31 PM
95itr-ej2's Avatar
when i press the break the wheel locks up, and i have the car on jackstands.
any idea of what it could be???
any idea if the caliper would be the same as one off of a sir/si??
thanks for the help
fatboy_zim
Aug 2, 2013 07:41 AM
emissionsux
Mar 15, 2007 11:28 AM
Lissav
29
Mar 17, 2006 11:07 AM
QWKPHKR
Feb 21, 2003 09:47 PM
