Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
people running wider wheels up front
Old Jan 6, 2010 | 05:07 AM
pleej's Avatar
Default people running wider wheels up front
did you find it better running wider wheels up front and if so in what way?
im thinking of running 9's or 10s up front and 8's on the rear.
Old Jan 6, 2010 | 05:23 AM
CivicSiRacer's Avatar
Default Re: people running wider wheels up front
For autocross I tried 15x7.5" wheels up front, 15x7" wheels in the rear with 205/50x15" tires all around. Worked much better for me with almost a stock suspension. Turn-in felt quicker, grip was definitely better and compared to my peers in my class I gained about 1 second on a 60 second course, whereas before I was neck and neck with my competitors.
Old Jan 6, 2010 | 05:24 AM
Stinkycheezmonky's Avatar
Suspetise...
For what purpose?
Old Jan 6, 2010 | 05:47 AM
pleej's Avatar
time attack and hill climb
Old Jan 6, 2010 | 11:50 AM
solo-x's Avatar
Sure, but, I run a 275 Hoosier on the front of my car on a 10.5" wide wheel, and a 205 Hoosier on the back mounted to a 6" wide wheel. On equal size tires, the advantages are not as noticeable. In general you get crisper turn in, can run a slightly lower tire pressure, and depending on the tire may see an increase in peak grip.
Old Jan 6, 2010 | 01:04 PM
JBrettHowell's Avatar
Similar to ^^^ 275's on a 10" rim in front, 225's on a 7.5" rim in back. Increased front grip with reduced track and weight in the back. Car handles great without any sway bars and slightly stiffer spring rates in front (yes, I know, I didn't believe either until I saw it with my own eyes).
Old Jan 7, 2010 | 03:43 AM
redzcstandardhatch's Avatar
something different
i ran 250mm advan slicks up front with 225 hoosiers in the back. worked surprisingly well.
stock DX bar up front, nothing in the rear.
wfocrx
May 27, 2014 04:17 PM
RSZero1
20
Sep 11, 2007 10:57 AM
devnull
Honda S2000
12
Jul 15, 2005 02:47 PM
Flux
Jul 30, 2002 11:00 AM
Flux
Jul 29, 2002 10:39 AM
