91 integra squeaking drivin me crazy
Old Jan 5, 2010 | 09:52 PM
sfellow2005's Avatar
Default 91 integra squeaking drivin me crazy
my da was in a wreck before i bought it. the damage was on the front drivr wheel/ fender. i fixed the suspension ie replaced springs struts bearings brakes rotors bushings cv axles the trans cus i thought it was internal also only have alt hooked up a/c and ps are removed timing elt and tensioner new throwout bearing new tires and rims and im just about to give up help me pls could it be my rack or the pressure plate or what im overlooking somthing and its makeing me insane oh only makes noise at 5mph and up
Old Jan 5, 2010 | 10:46 PM
da9love's Avatar
Default Re: 91 integra squeaking drivin me crazy
this may sound dumb but i had same problem and it was the speedo cable. lmk if that helps
Old Jan 6, 2010 | 05:18 PM
k ill try that in the morn and let you know i realy hope that works
Old Jan 7, 2010 | 08:49 PM
sweet you nailed it on the head bro
Old Jan 7, 2010 | 09:46 PM
da9love's Avatar
it was the speedo cable?
Old Jan 7, 2010 | 10:27 PM
mikekh10a's Avatar
i hear a squeaking sound when my cars going in reverse, neutral or in gear it doesnt matter..is this different?
Old Jan 7, 2010 | 10:30 PM
da9love's Avatar
but its always in movement when it makes the noise? thats what mine did. but did you get it fixed?
Old Jan 8, 2010 | 05:13 PM
yea it fixed it and yes its different if it makes the noise when in nutral and stoped cus it has to spin the cable to squeak if it makes a squeak while sittin still it would most likely be the throw out bearing
BigDrJ14
Mar 10, 2011 07:19 PM
eap
Jan 18, 2009 11:44 AM
DC5_R
Jun 30, 2003 03:35 AM
