mac boost solenoid failing?
Before today my solenoid would pulse with key on engine not running and would still pulse after car was started.Today my battery took a crap so i switched out with a new one but on the way home car felt as if it was hitting a ceiling.
I got home and checked over all my lines and couplers and found nothing out of the normal.I reset my ecu and then went on a test drive but car still felt the same.I noticed that the solenoid was not making any noise at all now(key on engine nor running).I have not hooked up my boost gauge to see what it is boosting to but i thought id run it by you guys to see if you think anything sounds fishy.
z6 vitara pistons/eagle rods 14.5psi tuned with neptune with boost by gear
