I Need Your Expert Advice about Tuning my Del Sol
I'm new here at HondaTech, and also to tuning cars, but I want to learn. I need advice about tuning my Del Sol and I know that this is the place to be in order for that to happen.
I own a 1996 Del Sol, with a d16y7 engine and I desperately want more power and speed. I want to build (with a professional's help) an all motor setup that prduces around 250 or more horsepower, with the best potential to eventually be turboed. I hope to occasionally run my car at the drag strip one day, but right now, all I really do is mess around on the street. I hope to spend no more than $4,000-$5,000, for now.
I've looked into doing either an H22a or a B18c5 swap, but I have several questions first.
1. Which of these swaps would best help me reach my hp goal (I want the
engine to be able to take a good beating also)
2. If I do an H22 swap, what are some modifications I could do in order to
reach ~250 hp?
3. What about if I do a B18c5 swap?
If you reply, thank you so much.
Also, know that I will probably have some more Noob questions to ask about your advice. I want to get this modification stuff right.
- Daniel
reach ~250 hp?
- Daniel
Straight up, you best and cheaper option is the B18C5 (JDM B18C Type R), the swap is a little cheaper as far as the components required to perform it. I am in the process of doing a swap in my '93 Del Sol Si, I am installing a B18C1. Engine, Header, Intake and tune up parts, I am around 4k. Expect to spend somewhere in the 5k+ range for the Type R swap. But you can find plenty of information on both swaps in this forum.
My build thread: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/93-del-sol-si-build-2703787/
yeah to make 250 out of an all motor d series setup while not impossible would be plain stupid and way to much more work and money than a swap.
i dont agree with number 1. i say go with the h22 with a nice valve train and i/h/e and a nice tune and youll be pretty close and yo will just love the torque that the big h22 put out lol
throw in a b18c1, the c5 is too expensive.
with $5000 you can acheive 250hp, if you spend it well on the right parts.
xx7xx
22
Nov 25, 2008 04:49 PM
trenenbaum
Jul 22, 2006 07:48 PM
