just got a wagovan
ok so i just picked up a wagovan with a bad head and i looking for sugestions as far as a head swap cause the car is auto and its a d15 i just want it to run and its dpfi so i may convert to mpfi
well get a vtec head for it make it a mini me if ur doing all motor i would go with 96and up d16y8 heads cuz they will give a slightly higher compression ration or us a d16z6 p28 head 92-95 vtec sohc
or u could go non vtec and use a pm6 head off a crx si 88-91 this is the most easiest one
your gonna need more than just head
head, intake manifold, throttle body, distributor,ecu, female ends for distributor , injectors and clips, resistor box, head gasket, timing belt,
you have wire up like 4 wires and extend to sensors to reach longer and switch ur tps sensor wiring around and insert to wires on the c plug of ur ecu connector im sure theres a write up for it i could walk u thourgh when u get all the parts
pics will be up tomarow its just a auto blue lx payed 500 the head is done on it need a good dpfi to mpfi write up or a si harness unmolested
I have a full (and good) D16a6 head + intake manifold and some of the parts you need for the conversion. PM me if you're interested.
I was going to do the conversion on a 91 Dx hatch several years ago (2001ish). I realized that I still have all of the parts boxed up in storage.
thenext
28
Jan 23, 2012 10:00 AM
