letting off brake pedal surges idle speed wtf?!
Old Jan 5, 2010 | 10:28 AM
bigbadspoon's Avatar
New User
Default letting off brake pedal surges idle speed wtf?!
This problem just started today, never happened before.
I have a 99 civic ex with the d16y8, and when I let off the brake pedal, the idle speed goes up from about 1000 to about 1500, and if I pump the pedal it climbs all the way up to 2k.
Some background:
This is my third post here, as I've been trying to resolve a rich condition/high idle. I thought I had it figured out when I disabled the FIAC (makes the car idle fast when cold, similar to the thermo valve in older civics). Started it up after that and did the re-learn procedure and it ran great for about 30 mins. After I took it for a short drive, the light came back on and now I'm getting a code 10, as opposed to the 45 I had before. Incidentally, both indicate a rich or lean condition. It smells like raw gas all the time andI'm about 100% sure there's no random misfires, so that leaves it with a rich condition.
Unfourtunately, I don't have a scope, only a multimeter, so pulling O2 voltage is completely useless.
Next, I cleaned out the IAC, which was pretty dirty, but didn't seem excessive. Anyway, that didn't solve anything. I still get the code 10. Though I'm curious what happened to the 45...
Just as an aside, I also checked the IAT and ECT sensors and they're both testing perfect according to that graph of resistance vs temp that's floating around the internet.
Vacuum leaks; I've tried pinching off every line in turn to see if anything changes, as this should indicate a leak. At one point the line leading to the purge solenoid caused it to change, but it's not doing that anymore, so I may have just pinched that one off while the solenoid was open.
I think that covers everything I've checked so far, and I'd love to hear some more input.
Old Jan 7, 2010 | 10:13 PM
tommyboy4's Avatar
New User
Default Re: letting off brake pedal surges idle speed wtf?!
Mine drops idle when pedal is pressed & idles out at times. I think its an electrical issue, possible ground in my case.
Old Jan 8, 2010 | 05:22 AM
civicvtec44's Avatar
vac leak... u got power breaks?if so cheack for fluid on outside of boooster (eattin away paint) if so u got a LEAK IN THERE. which can also be a source of the vac leak
Old Jan 8, 2010 | 06:53 AM
Former User's Avatar
Have you cleared the ECU to see whether code 10 returns? Could be a bad check valve in the vacuum hose leading to the brake booster.
Old Jan 8, 2010 | 09:07 AM
speedooo's Avatar
Maybe it's just me but any car with power brakes draws vacuum when the pedal it pushed and naturally makes the idle rise
Redprelude98
25
Nov 30, 2014 02:15 PM
ser13
Sep 10, 2010 05:48 AM
lude98SH
Jan 24, 2006 03:39 PM
iwannaboostmyteg
Feb 7, 2004 10:43 AM
