rsx to 90 DA cluster
Old Jan 5, 2010 | 06:52 AM
swirve1's Avatar
Icon3 rsx to 90 DA cluster
dose any one know how to wire a rsx gauge cluster in to a 1990 da whats the diagram for the wires if their is one
Old Jan 5, 2010 | 01:37 PM
1993-eg1's Avatar
Default Re: rsx to 90 DA cluster
well i know u will need a speed sensor from an 94-01 Integra and will need to run the wires for it
Old Jan 6, 2010 | 06:22 AM
swirve1's Avatar
i know that i will half to do those things im lookin for the pinouts
Old Jan 7, 2010 | 05:58 AM
swirve1's Avatar
any other thoughts from any one is their a thread for it
Old Jan 7, 2010 | 09:54 AM
DubVTeg's Avatar
it's going to be a lot of work and wiring. if you're good with wiring, it shouldn't be too hard. a lot of the same stuff that you have to do to wire up an s2000 cluster, you're going to have to do with the rsx one. the main reason for that is the rsx cluster uses a digital speed sensor signal just like the s2k, so you're going to need a digital converter to convert the signal from analog to digital. i'm not too sure about the work to get the other sensors to work, but i would figure that they would probably be similar too. try checking out some threads for the s2k cluster swap and i'll bet some of it is close to being the same.
here's a thread of a guy putting one in an ek, it's going to be pretty much the same for you, except you're going to need to source an electric vss. hope this helps some.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/rsx-cluster-into-ek-civic-1380816/
integra_ls_2dr
19
Jan 5, 2010 06:25 PM
swirve1
May 25, 2009 08:03 PM
90civicturboed
Jul 14, 2006 10:46 AM
purple98ek
Jun 3, 2005 08:27 AM
