**Official Cheap Mod's**
Old Jan 4, 2010 | 10:21 PM
Dailydriver92's Avatar
Default **Official Cheap Mod's**
Looking through the forum but I could not find a thread that was just for small and cheap modifications.
This is the sole reason for me making the thread, I decided not to make this thread in appearance or into another Category because the Mod's could be just about anything from ITB to CAI. A headlight tint, mirror change, ANYTHING.
I got this idea from vwvortex.com and thought that it was a great idea for anyone who was bored and wanted to try something new and cheap.
Lets keep the price at anything UNDER 100$
RULES: This is the format you HAVE to use.
::::::: Mod Name:
::::::: Why the MOD is worth it:
::::::: Cost:
::::::: Where to buy:
::::::: Time required:
::::::: Difficulty:
::::::: DIY:
::::::: Picture(s):
How this will work. I will update this thread every so often and put every mod on this post. I will organize it by page. Hopefully we will get alot of mods.
Page 1:
Broadway 280mm rear view mirror
Jdm/si Clock
Cheap ITB Setup
Type-r Floor Mats
Radio block off plate/Radio Relocater
JDM Amber cluster
License plate relocator
Last edited by Dailydriver92; Jan 5, 2010 at 05:52 PM. Reason: Need to put mods into list.
Old Jan 5, 2010 | 05:28 AM
300whpej's Avatar
Default Re: **Official Cheap Mod's**
so why did u not start the list off??
Mod Name: Broadway 280mm rear view mirror
Why the MOD is worth it: eliminates blind spot
Cost: $20
Where to buy: pwjdm.com or local tuner shop (i got mine from a local shop)
Time required: about 30 seconds including opening the package
Difficulty: you'd have to be brain dead to not figure it out, even with the instructions written in jibberish
DIY: noob difficulty
Picture(s): none, google search tho
Old Jan 5, 2010 | 06:35 AM
turboteg90's Avatar
pm for noodz
1.remove manifold
2.get 4 dixie cups
3.place dixie cups on head intake holes
4.enjoy your new itb set up.
Old Jan 5, 2010 | 06:39 AM
jtaylor16's Avatar
Mod Name: Jdm/si Clock
Why the MOD is worth it: You'll always know the time and never be late again lol
Cost: $30-$50
Time required: about 2 minutes
Difficulty: pop out the four way and take out the dummy socket and plug it in.
Diy: Your an idiot if you cant figure out
Pictures: google it or any jdm site
Old Jan 5, 2010 | 07:30 AM
shoklid's Avatar
you should have said no rice lol lol you're gonna get some. haha. but good idea tho
Old Jan 5, 2010 | 08:54 AM
Mod Name: Cheap ITB Setup
Why the MOD is worth it: if you do not want to buy a full kit.
Cost: 20$ maybe?
Where to buy: Rona, Home Depot.
Time required: Anywhere from a couple of minutes to an hour if you are that dumb.
Difficulty: Easy.
DIY: 1. Take a 90 degree pipe that has a clamp on both ends.
2. Cut the pipe in half.
3. Attach end with clamp to the engine side and tighten it.
4. Take Filter and hose clamp it to the pipe.
Picture(s): None.
Old Jan 5, 2010 | 09:13 AM
92ehatch's Avatar
Cost: 20$ maybe?
Difficulty: Easy.
Picture(s): None.
cheap intake?
Old Jan 5, 2010 | 09:15 AM
shoklid's Avatar
Originally Posted by 92ehatch
cheap intake?
haha yea. itb haha
Old Jan 5, 2010 | 10:07 AM
ultraplayer26's Avatar
Mod Name: type-r floor mats
Why the MOD is worth it: it keeps the oem carpet clean,and it looks cool..
Cost: $65.00
Where to buy: ebay
Time required:1min
Difficulty:so easy its not even funny..
Old Jan 5, 2010 | 05:35 PM
Bump for no new good ideas.
Old Jan 5, 2010 | 05:42 PM
VihnSta2's Avatar
::::::: Mod Name:Radio block off plate/Radio Relocater
::::::: Why the MOD is worth it:Because its tyte as ****
::::::: Cost:EST: $20
::::::: Where to buy:Ebay,Honda Dealer
::::::: Time required:about as long as you take?
::::::: Difficulty:Moderate
::::::: DIY:
Remove your head unit from the top of the console, Snap in block off plate remove plastic pocket behind cup holders, re route the wires. ENJOY
::::::: Mod Name:JDM Amber cluster.
::::::: Why the MOD is worth it:Cause.
::::::: Cost:Around $11
::::::: Where to buy:Ebay led's
::::::: Time required:As long as you take.
::::::: DIY:Remove your gauge cluster, Clip clear plastic off, Remove gauge faces by unscrewing. Insert red LED'S Ground black wire and positive wire goes into cluster fuse. Re install everything and enjoy!
::::::: Mod Name:License plate relocator
::::::: Why the MOD is worth it:...
::::::: Cost:about 5 bucks
::::::: Where to buy:Lowes,H depot ECT
::::::: Time required:5 mins
::::::: Difficulty:Easy
::::::: DIY:Buy 2 home depot L brackets 2 washers hex screws and wing nuts. install L brackets to desired position under the top bumper lip, insert washers in screws.then insert all that into plate then behind the L bracket tighten wing nuts. Then install the whole assembly and have fun being a cool kid.
::::::: Picture(s):
::::::: Picture(s):
Old Jan 14, 2010 | 08:42 PM
zmjohnson's Avatar
Icon2 Re: **Official Cheap Mod's**
Cost: 20$ maybe?
Difficulty: Easy.
Picture(s): None.
Exactly how does this make an ITB (Individual Throttle Body) setup? Correct me if I'm wrong, but this doesn't sound anything like what I've read or seen (youtube).
Old Jan 14, 2010 | 08:58 PM
97ej6dx's Avatar
Mod name: Integrated Rear Fog lamp (or lamps)
Why the MOD is worth it: For traffic behind you to clearly see you in inclimate rain fog or snow.
Cost: 5 dollars for switch.10 bucks for wire and if you want to get fancy another 10 for loom
Time:About an Hour
Difficulty: Easy if you can wire
DIY:
1. Cut both brake signal wires from your inner tail lights (if you have a 6th gen coupe or sedan ) If you have a hatch you may have to get different bulbs for the lower tail light location below the turnsignals (6th gen)
2.Run wire up to front to your purchased switch or to your existing foglight switch.
3. Enjoy!!
Infact the 6th gen coupes in Europe came with an integrated rear foglamp in the inner taillights depending on what side of the road the country drove on. You can choose to do both if you wish or just the drivers side. Totally up to you. Now you wont have to worry about cutting your bumper for a rear foglight and still be able to enjoy the functionality.
Old Jan 15, 2010 | 12:44 AM
honisoto's Avatar
MOD NAME: "I <3 my honda" sticker
WHY THE MOD? It will give you 10000000+HP. lol
Cost: 5-10 dollars
Time: under 4 minutes..
Difficulty: Super easy mod..
DIY:
1. buy the damn sticker
2. stick it to where ever you want
3. instant 100000000+HP.
ROFL!! jk
Old Jan 15, 2010 | 05:34 AM
dale m.'s Avatar
Cost: 5-10 dollars
DIY:
ROFL!! jk
lol
Old Jan 15, 2010 | 05:43 AM
90Rexx's Avatar
this thread is a total FAIL lol...
but heres my mod
Mod Name: Throttle body and intake gasket match
Why : maybe net a few horsepower
Cost: 100$ for a dremel tool, and new gaskets
Difficulty: Medium
DIY:
1: remove your intake manifold and throttle body
2: mock up your new gaskets and color in with marker the areas of metal that stick past the gasket hole
3: dremel the **** out of it all until everything matches perfectly
4: put it all back together and enjoy
5: get upset becuase you cant notice a significant power increase
felipe69
Mar 5, 2008 06:30 PM
HybridRacer69
Jan 31, 2005 07:23 PM
