what is the correct axle to use?
Old Jan 4, 2010 | 09:46 PM
eracer08's Avatar
Default what is the correct axle to use?
I have a 95 integra with a b16a1 with y1 trans (cable lsd). Part store can't match my axle. The axles are longer than the ones I have. Does anyone know which ones are the correct ones to use.
Old Jan 5, 2010 | 08:34 AM
ironcheftony's Avatar
Default Re: what is the correct axle to use?
94+ half shaft with 94+ integra axles, if ur car has abs, get GSR ones if not Ls are fine
if u have a a 91-93 half shaft, get some 93 integra axles
Old Jan 5, 2010 | 09:07 AM
eracer08's Avatar
the problem is idk what the ones i have are from.
Old Jan 5, 2010 | 01:32 PM
eracer08's Avatar
thanks i got the right ones.
SoHc94
Feb 9, 2007 06:00 PM
xH22xTEGx
Jan 12, 2006 06:48 AM
ACRProject
Mar 15, 2004 07:59 AM
foursquarepunk04
Feb 3, 2004 08:42 PM
JJ-Built
Jan 2, 2002 08:27 AM
