wtb or borrow 50mm crank pulley tool
Old Jan 4, 2010 | 09:15 PM
dleccord's Avatar
Default wtb or borrow 50mm crank pulley tool
located in sacramento just need to borrow the 50mm pulley tool for a weekend. or if you're selling it, lemme know what you got. thanks
Old Jan 4, 2010 | 09:26 PM
lthao61's Avatar
Default Re: wtb or borrow 50mm crank pulley tool
i would let you borrow mine but its two half hours from my house
Old Jan 5, 2010 | 12:34 PM
civic_driver09a's Avatar
why dont you jus raise the drivers side and have the passangers side on the ground have someone sit in the car pressing the brakes while you have your breaker bar trying to break the bolt loose
Old Jan 5, 2010 | 01:41 PM
Ricextacy's Avatar
forreals??? thatll work??
Old Jan 5, 2010 | 01:45 PM
yea it worked for me when i had to change my timing belt..the only time it didnt work was on my old block but then again not even with the pully tool or high powered impact wrench at my boys shop couldnt break it loose.
Old Jan 5, 2010 | 06:17 PM
SGVridgerunner's Avatar
Also, it's a 2" hex on the pulley, so you can buy a 1.5" - 1" reducer bushing and 1.5" coupling (steel) from Home depot. Thread the two together, insert the hex end into the pulley and hold on to the coupling with a pipe wrench, etc. then loosen the bolt through the 1" reduction hole.
Old Jan 5, 2010 | 09:15 PM
akandok's Avatar
I have one... I can let you borrow it but you would have to leave me something of value so I can get the tool back from you.. My shop is in south sac. PM me
BLKFLSH
Apr 10, 2011 01:54 PM
budomove
Nov 2, 2007 07:37 PM
grngsr01
Oct 23, 2005 05:47 AM
Draggin99Si
59
Feb 20, 2005 11:59 AM
yuckymucky
21
Mar 30, 2003 07:04 PM
