91 civic hatchback help
Old Jan 4, 2010 | 07:05 PM
spinoza06's Avatar
New User
Icon6 91 civic hatchback help
I recently purchased a 91 hatchback with a b18a1 in it. I used the wiring harness it came with it but it doesnt seem to want to start. I tried bypassing the starter and the engine turned over. the dash lights up when i turn the key but nothing happens. Im thinkin it is the wiring harness because it seems as if the previous owner made it from scratch. when you swap an engine do you need to also change the computer? Do i need a wiring harness from a 91 hatchback or the acura?
Old Jan 5, 2010 | 07:08 AM
Einhander276's Avatar
Default Re: 91 civic hatchback help
From what i understand you need a completely different ECU and harness to go with the engine for it to work properly.
Try researching here, there is bound to be something.
i know for my 91 civic hb i need a P26 or P72 ECU and a new harness for all the wires.
hope this helps...
Old Jan 5, 2010 | 10:05 AM
turbohatchBnuts's Avatar
u need a pr4 ecu obd0 and the orginal harness from the car getts modifed to work ur engine what model type do u have a si or dx?
Old Jan 5, 2010 | 11:32 AM
Kid_SiR's Avatar
hey can u take pics of the harness in the car u have now depends on wat harness he use cuz civics come two injestors an if they didnt switch it over that culd be the isssue it u can another harness either dx or si
Old Jan 5, 2010 | 11:42 AM
yea you need to kno if ur car is a si or dx first of all
then if si its a plug and play matter might have to extend sum wires
but if its a dx u have to convert it to mpfi multi port fuel injector
dx comes dpfi dual point fuel injector
if its dpfi u have to convert to mpfi
Old Jan 5, 2010 | 01:39 PM
spinoza06's Avatar
New User
Im guessing it's an SI
Old Jan 5, 2010 | 01:40 PM
spinoza06's Avatar
New User
Here is what it looks like.
Old Jan 5, 2010 | 02:45 PM
is it painted red or have red tape on it looking at its a mpfi harness
ur ecu plugs look at the back of them the big one is ur A plug a3 is your 2 cylinder injector and a7 is ur 4 number injector make sure these are on the back of ur A plug and then u kno u have an si or mpfi conversion done
hondacurious
Sep 30, 2014 07:37 AM
RACETEGGY
Jun 4, 2014 12:57 PM
DaIntegra1991
Feb 5, 2013 07:27 AM
hatchback_al
Nov 29, 2004 10:55 PM
Sean_b
Jun 23, 2004 01:19 PM
