LS turbo
then what else would i need other than the stuff that comes with turbo kit, the exhaust manifold for my engine, and a blow off valve and bigger pipping? can you help me out this is gonna be my first time turboing my integra and i want it to come out correct and powerful... thanks in advance...
well first i would make sure my engine would be ready to handle boost. stuff like mileage and maintenance habits along with normal wear will determine if u can boost or not. secondly i recommend choosing the right turbo for what you want to do. depending on how far you go you might need to upgrade fuel, cooling, ignition, and ecu inputs. u need to run the parts that will work well with each other to handle with the added stress of boosting
SOHCam
May 19, 2002 11:36 PM
