need some advice on 400-550hp ls vtec
Old Jan 4, 2010 | 09:50 AM
dc2luver's Avatar
Default need some advice on 400-550hp ls vtec
Any advice would be great. Also to mention this car will be my daily. so heres what i've come up wit so far..
Block:
ls 84.5mm GE godzilla sleeves
rods??(any suggestions)
pistons??(any suggestions)
ls crank
moroso oil pan
Head:
gsr head
ported and polished
port mached
cams??(any suggestions)
ferrea valve train
intake manifold??(any suggestions)(anyone ever used endyn's manifold??)
Transmission:
gsr trans
carbon syncros
quaife lsd
Boost App:
38mm TIAL wastegate
inline pro manifold
sc61
HkS BOV
Old Jan 4, 2010 | 09:59 AM
Poootie's Avatar
Default Re: need some advice on 400-550hp ls vtec
Block:
rods??(any suggestions) EAGLES
pistons??(any suggestions) CP 9:1 or 9.7:1
ls crank
moroso oil pan
Head:
gsr head
ported and polished
port mached
cams??(any suggestions) CRT or ITR will do justtt fine
ferrea valve train
intake manifold??(any suggestions)(anyone ever used endyn's manifold??) for the $$ i'd go Victor X
Transmission
gsr trans
carbon syncros
quaife lsd
Boost App:
38mm TIAL wastegate
inline pro manifold
sc61
HkS BOV
also is that a block you chanced apon, or plan on doing? (because i'd stay 81mm or go 84mm if you plan on uping the power some day)
Old Jan 4, 2010 | 10:10 AM
dc2luver's Avatar
Thats a block i came upon.
Old Jan 4, 2010 | 10:25 AM
90blackcrx's Avatar
Pistons and rods, I'd go with je pistons 9:1, an manley or eagle rods. Eagle rods are suppose to be maxed out at 500hp, but I've seen plenty of guys making more. Intake manifold, I'd suggest a victor X , and cams, you can make the power on gsr cams or upgrade an go with like a skunk2 pro 1 series head package.
Old Jan 4, 2010 | 11:35 AM
DA TeG 90's Avatar
Skunk2 stage2 cams, cp pistons, manley turbo tuff rods. Good combo!
Old Jan 4, 2010 | 12:04 PM
dc2luver's Avatar
appreciate it
Old Jan 4, 2010 | 12:09 PM
YARO.'s Avatar
cp 9:1 piston
Manley turbo tuff rods
Skunk2 tuner1 or pro 1 cam depending on the turbo
Victor X IM
For the turbo kit go with a tubular manifold, 3" dp, 44MM+ wastegate, decent core intercooler.
Don't worry about port and polish, morosso pan, Spend your money alse where like in the head good valves/springs/retainers/guides/new lost motion.
What parts do you have so far?
Old Jan 4, 2010 | 12:17 PM
dc2luver's Avatar
Originally Posted by YARO.
cp 9:1 piston
Victor X IM
I have the block. And cash. Just seeing others peoples advice/opinions. Before i start ordering.
Old Jan 5, 2010 | 11:19 PM
sloturbohatch's Avatar
cp and manley turbo tuff rods are the best just throw sum type r cams in it, they make efficient power in that power range
Old Jan 6, 2010 | 06:40 AM
DA TeG 90's Avatar
I would try with skunk2 tuner2's over the tuner1's. I think they make a lil more power...
BLKTeg94
Sep 7, 2009 01:44 PM
BLKTeg94
Aug 24, 2009 03:45 AM
hkwe36
Southeast (Sales)
May 15, 2009 10:16 PM
APP95bomexLS
Sep 4, 2003 07:55 PM
tegasaurus
Dec 10, 2002 07:46 AM
