how do "you" pressure test your cooling system
Old Jan 4, 2010 | 07:51 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default how do "you" pressure test your cooling system
When i pressure test my system, I usually rent a pressure tester from autozone and put enough pressure in it to match the radiator cap. This is how i check mine becuase i dont want to find a leak after the car has been started.
Would you say this is an accurate way of testing it? I'm asking this because I'm having an issue with an electric water pump leaking with cap pressure to it.
Old Jan 4, 2010 | 12:56 PM
delsolproblems's Avatar
Default Re: how do "you" pressure test your cooling system
That's an excellent first step in checking the system. I'd remove the thermostat so you can do the check with the system open. Followup tests would include pressure tests after bleeding and at normal operating temp. I'm sure you know how to be careful when running with a coolant leak.
Old Jan 6, 2010 | 04:59 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
yeah we figured out the problem it wasn't me it was a bad pump.
Old Jan 6, 2010 | 05:28 PM
As long as it wasn't you leaking. :p
Old Jan 7, 2010 | 12:23 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
lol, i actually helped the company come up with a better way of testing before they send these pumps out to people so now they can feel confident that a pump isnt going to come back
Neo218
Mar 19, 2010 07:39 PM
mouab18c1
Dec 18, 2009 09:17 AM
dbb
Feb 27, 2009 10:49 AM
steveharrmr23
Oct 17, 2008 12:28 PM
