D16Z6 Compression Question...
What's the average or should I say healthy range of compression in a stock D16Z6? I can't find the info anywhere, just the actual ratio.
Reason I ask is I did a compression test earlier and it's...
Cyl #1: 180psi
Cyl #2: 160psi
Cyl #3: 160psi
Cyl #4: 168psi
Did the test twice got the same numbers, I'm assuming it's around 160psi for a healthy engine and #1 just has a bunch of carbon build up. Motor was rebuilt and had around 80k miles put on it since the rebuild, 194k total miles.
Cyl #1: 180psi
Cyl #2: 160psi
Cyl #3: 160psi
Cyl #4: 168psi
Oh and if it is carbon build up in #1, anyone have any cleaner suggestions? I heard some not so good things about Seafoam so I was thinking maybe BG-44k.
xXx Justin xXx
May 15, 2003 09:42 PM
