need help starting my 91 dx hatch
Old Jan 3, 2010 | 11:33 PM
barney_SI's Avatar
Default need help starting my 91 dx hatch
i have a 91 dx hatch which i put in a zc dual cam 1.6 which is not wanting to start i did do the conversion of the injectors connector which is the only thing i changed in the harness. the thing is that it has gas, spark, oh but im using a 1.5 dizzy does that matter? but it is not whanting to start.... any help please let me know any ideas out there?
Old Jan 4, 2010 | 12:38 PM
D16SiHatch's Avatar
Default Re: need help starting my 91 dx hatch
if its a dpfi d15 dizzy, then yes it matters. you need a mpfi dizzy, and its obd# needs to match the obd# of your ecu.
Old Jan 4, 2010 | 01:15 PM
Fuzzy Rhubarb's Avatar
Plus, if you're using your original PM5 ecu, it's not going to work. You need to be using a PM6 or preferably a PM7 ecu. You're also gonna need the right distributor. The one from the old setup will not work. You gonna need the TD03U dizzy and the CYP sensor on the other cam will also need to be wired in. All that's left are the injectors, and if you wired them in already, you should be good to go.
jstjoh02
Nov 25, 2013 03:39 AM
91dxhatch
Sep 17, 2006 06:39 PM
jarvis199
Dec 15, 2004 06:47 AM
hockeyplayad2
Jan 8, 2004 06:22 PM
nerces
May 2, 2003 09:54 AM
