ctr motor in 95 gsr
Is your motor blown? Why not get an ITR motor?
As far as the mounts are concerned the motor is a direct swap. The only problem you may have is the ODBI/OBDII issue but that will be resolved with adapters or an engine harness swap?
Timing belt wont be an issue and yes B series are identically the same. I believe your going to have to change the Block motor bracket that bolts up to the driver side motor mount being that EK and DC/EG are different.
Driver side upper mounts are different, as well as intake manifold design and throttle body. You will need an ITR style Intake, throttle cable and cable braket.
OmgDelSol
29
Apr 16, 2013 09:30 AM
Ajohatch
Nov 13, 2005 08:13 PM
