Starter Problem
Old Jan 3, 2010 | 03:01 PM
joexjoex44's Avatar
Icon6 Starter Problem
01-01-2010, 02:19 PM #1
joexjoex44
1992 Honda Civic
Starter problems
car will not start. starter wont get signal. fuel pump turns on. tryed changing the clutch switch, not it. checked the fuses, not blown. some are not getting any juice, one of which is the starter relay fuse. any ideas?!?!
01-01-2010, 03:13 PM #2
EFPhilly
Re: Starter problems
the wiring for the starter is easy. Just take the starter out and take it to the parts store. Have them test it, if its good, take a 9 volt battery and check for voltage at the other end.
__________________
93 eg/ek hatch. B18A1 block, gsr eagle h beam gsr rods, cp pistons, gsr crank, stock head ported. 60 garret turbo, rc750's, greddy bov, turbonectics wastegate...My thread:: https://honda-tech.com/forums/forced-induction-16/my-b18a1-turbo-project-2683624/
01-01-2010, 03:56 PM #3
joexjoex44
1992 Honda Civic
forgot to mention, the starter is brand new.
01-01-2010, 04:19 PM #4
Snap-off
is it an aftermarket starter? sometimes the solenoid is bad, try tapping it with a pry bar and see if it turns on, but make sure you have power up to the starter solenoid first.
01-01-2010, 04:46 PM #5
S_F
Jump the contacts on the solenoid with a big screw driver while someone turns the key. If it starts the solenoid is bad. Some times they are no good off the bat.
01-02-2010, 10:42 AM #6
joexjoex44
1992 Honda Civic
starter solenoid is good. anymore ideas?
01-02-2010, 12:58 PM #7
Snap-off
so you are getting power to your starter, the starter is engaging and disengaging, correct?
if so, then make sure you are getting fuel up to your fuel rail would be my next step, i mean there's not that many things, after fuel, make sure you have spark
01-02-2010, 01:11 PM #8
itsnotfast
Quote:
You don't need to have someone turning the key on. All you need to do is have the key in the onII position and jump 12 volts to the starter solenoid. If the starter turns, you have a signal problem and just trace the wire back until you find your problem.
__________________
97 EJ8-Daily 07 GSXR600 94 DC4-Sold
Quote:
Originally Posted by B16acivicsedan91
If its just the JDM look your going for you can always overnight nuts and bolt from a JDM home depot lol
01-02-2010, 06:10 PM #9
joexjoex44
1992 Honda Civic
do u think the ignition switch might be bad? its weird, i checked some other fuses, for example my headlights, taillights, etc, its showing no juice going to them, but they still work? bad wiring?
01-02-2010, 07:03 PM #10
Snap-off
if they work, then they have to have to have power going to them, cause they work. the ignition switch is a possibility, what kinda car, year and model?
01-02-2010, 11:00 PM #11
joexjoex44
1992 Honda Civic
its a 92 civic hatch, not sure model. has a b16a obd1 SiR motor
Old Jan 3, 2010 | 03:02 PM
Gunmetal_B20_Hatch's Avatar
Default Re: Starter Problem
WTF is this ****???`
learn2internet?
C Dubya's Avatar
wut
EKSedAndy
Mar 17, 2011 03:29 AM
joexjoex44
10
Jan 2, 2010 10:00 PM
mugen94
Aug 9, 2009 03:16 PM
FSS13foxtrot
Apr 1, 2008 08:05 PM
pasenast
Apr 14, 2007 04:20 PM
