88' CRX DX Manual, Shuttering when accel.
Old Jan 3, 2010 | 12:14 PM
Razster's Avatar
Icon2 88' CRX DX Manual, Shuttering when accel.
So just a couple days ago the Car started to shutter when I would put it into any gear. Going into gear is fine and the car idles and revs just fine.
Oil is golden, recent oil change, and new plugs/wires.
Is this a clutch issue or something worse in the trans?
Any help would be much appreciated. Thank you!
Old Jan 3, 2010 | 01:19 PM
Razster's Avatar
Default Re: 88' CRX DX Manual, Shuttering when accel.
Alright!
So it turns out to be my dizzy all crusty and what not - cleaned it out with WD40 and let it dry after cleaning off the corrosion which has probably been there since 1988...
Shifts like made and runs smooth now :/ Crazy!
Wonder how much a new distrib would be?
Old Jan 3, 2010 | 01:24 PM
Radim's Avatar
Mine does the same thing but only in first, and very very slightly in 2nd.
Old Jan 3, 2010 | 01:26 PM
Razster's Avatar
I also bought a can of WD in order to clean ALL the wire connections, which might be something worth doing if you have time.
These engines are so fun to work on, I love them.
Old Jan 3, 2010 | 01:28 PM
Radim's Avatar
Awesome! I'll check it out! Thanks.
Old Jan 3, 2010 | 02:30 PM
Radim's Avatar
What exactly did you clean and how?
I used carb cleaner to clean the contacts to no avail.
However my module was loose so tightened that up.
bthomas67wagon
22
Aug 26, 2014 08:36 AM
crxblues
25
Aug 21, 2008 11:29 AM
TrackSpeedRacing
Jul 20, 2005 04:16 PM
