B20 Vtec built now needs to be tuned! What's the best affordable way to go?Crome/s200
Old Jan 2, 2010 | 08:50 PM
ALLOUT CL55's Avatar
Default B20 Vtec built now needs to be tuned! What's the best affordable way to go?Crome/s200
This is my set up...I'm running a 4.7 final drive itr tranny
B20b Block
84mm
Cp 12.5.1 Pistons
Total seal rings
Eagle H beam rods
Arp Head Studs
Arp Rod Bolts
Oem Type R oil pump
Oem Water pump
Oem Timing Belt
Golden Eagle Vtec line (-4)
Unothidox Crank Pully
B16 Head
5 angle valve grind intake
3 angle valve grind exhaust
Port an polished
Crower valve springs an retainers
Titanium valve guides
Ferrera 1mm oversized valves
Buddy Club Spec 4 Cams
skunk2 Cam Gears
Head was Milled Thirty thousandths 0.030
Bisimoto V2 Prototype Header B series
getting tuned next week. what kind of numbers should i expect?
Old Jan 3, 2010 | 01:22 AM
Default Re: B20 Vtec built now needs to be tuned! What's the best affordable way to go?Crome/
Anybody??
Old Jan 3, 2010 | 05:26 AM
kulo's Avatar
ectune
Old Jan 3, 2010 | 06:36 AM
mtber's Avatar
1. Contact your local dyno tuners to see if they tune the rom version of eCtune, Neptune etc.
2. (You didn't list your injector size or fuel pump)
Discuss your setup & fuel system to determine if everything will work properly.
3. Get a chipped obd1 vtec ecu with a basemap for your application.
4. Get the car dyno tuned.
Old Jan 3, 2010 | 11:20 AM
I have stock injectors/ walbro fuel pump and a stock p28 ecu. Maybe I should just give them a call. Thanks for the advice... How much whp should this set-up make?
Old Jan 3, 2010 | 01:29 PM
92SikHatchBak's Avatar
It's not about what the motor "should" make, cuz everyone can just throw a number out there.
Give the shop a call and get it dyno'd and tuned
The numbers on the computer never lie
Good luck!
Old Jan 4, 2010 | 04:47 PM
mtber's Avatar
Your going to want to order some injectors :-)
Old Jan 4, 2010 | 08:15 PM
what size injectors is needed?
Old Jan 5, 2010 | 10:42 PM
thumper64's Avatar
Maybe DSM blue or black top 450s? I just looked and that will support about 300hp at 80% duty cycle, and the highest I've seen B20Vs go is about 250 all motor.
Only suggesting DSMs since they're cheap and I have a resistor box left to sell, haha.
Old Jan 6, 2010 | 02:12 AM
.Manny.'s Avatar
Touching My Member
I'd get rid of that crank pulley for something with a dampener.
Old Jan 8, 2010 | 05:52 PM
em1effekt's Avatar
hey man let me know how it goes with your stock injectors i have a similar set up debating on weather i shud upgrade em
Old Jan 8, 2010 | 06:28 PM
jordaninu's Avatar
s300
Old Jan 8, 2010 | 07:51 PM
mtber's Avatar
Stay away from DSM injectors.
I would recommend atleast 370cc injectors. If you plan on running e85 I would go with something larger.
You can pickup precision 440cc injectors for under $220 bucks (we stock them).
Old Jan 14, 2010 | 09:52 AM
jmart41791's Avatar
anybody know how to get a basemap for startup on a freshly built motor? i dont want the startup to be misfiring and all that bad ish? im going with a s300 but know who or where i can get a basemap for initial startup and break in? i dont think dynoing a motor with 5 miles on it would be a good idea?
Old Jan 14, 2010 | 10:32 AM
MAperformance's Avatar
Crome will work just fine for what you're doing if you're on a very tight budget!
Otherwise Neptune, or S300 will work.
I personally suggest AEM Ems.
Old Jan 15, 2010 | 05:20 PM
Sr420Det's Avatar
when u buy the s300 the software should have basemaps included, if not u can download them off hondatas site.
Old Jan 15, 2010 | 06:28 PM
mtber's Avatar
Contact the dealer you bought the system from for support.
We provide all of our customer's with a basemap pre-uploaded to their s300 module specifically for their setup.
ALLOUT CL55
Northern California (Sales)
28
Jul 11, 2011 06:06 PM
ALLOUT CL55
11
Jul 11, 2010 04:04 PM
ALLOUT CL55
30
Jun 27, 2010 09:32 AM
H-allmotorda9
Mar 13, 2010 05:08 AM
mikeledez
Oct 31, 2009 07:54 PM
