ABS broke...
I don't which part is this.. can anyone identify what part I need to replace?
I was backing up, didn't see a rock in the rear view, somehow, it hitted one of the line and the ABS Light went on.
edit: the white spot on the line..
its possible you might have just triggered an abs code from the impact on the abs line, you might need to just clear the code from the abs computer....unplugging the battery for 30 minutes should do it
do you have the green connectors in the ecu area on the passenger side behind the kick plate? one of those should be an abs connector you jump, which causes the abs light to flash to take the code down, im curious to know what code.
get a paper clip and jump the connector spawne is talking about and turn the ignition on it should flash an abs code. i'm thinking that you may have damaged the wires going to your wheel speed sensor. inspect the damage area to see if any wires are broken.
Before you buy a new one have a look at it. The sensor is magnetic and sometimes metal filings will connect the pickup and the pulser, causing a fault. If that's your problem you can fix it by clearing out the filings with a magnet or a metal brush.
