EF not going over 75
Old Jan 2, 2010 | 07:36 PM
sir4doorking's Avatar
Default EF not going over 75
ok i am doing this post for a friend he have a 90 ef it was 4 speed he change the tranny with a si tranny and it will not go over 75-80 in 4th and 5th no powere but in 3rd it will go over that speed. lol i am lost on this one when he told me this thanx for any replays.
Old Jan 2, 2010 | 08:47 PM
Radim's Avatar
Default Re: EF not going over 75
D15B1?
Old Jan 2, 2010 | 09:23 PM
Eighty-Nyne's Avatar
****ing weird.
Old Jan 2, 2010 | 11:28 PM
~sp33~'s Avatar
EFB055
The engine the car started with doesn't have much power. So in third, where it has a shorter ratio, it has the mechanical advantage to get the car over that speed.
It's probably a tired engine? Give a service and see how that goes.
Old Jan 2, 2010 | 11:31 PM
pi Ka chuuu's Avatar
upgrade to dual cam
Old Jan 2, 2010 | 11:33 PM
Foxcow's Avatar
There is something wrong but we would need more info to diagnose the problem. In that configuration, the car would take longer to get to and above 75 but nonetheless, it would get there.
Old Jan 2, 2010 | 11:37 PM
DCRB's Avatar
that's wierd. my car went over 75 in both of those gears with my si trans. is his timing still dead on? is the trans making any noise? is the clutch slipping at all?
mine went through a quart of oil a week if not more, burning it all, and still went 90 +...
Originally Posted by pi Ka chuuu
upgrade to dual cam
stfu post ***** that's not even remotely answering his question.
Old Jan 3, 2010 | 11:07 AM
Originally Posted by Radim
D15B1?
yeah the d15 is all stock
Old Jan 3, 2010 | 11:09 AM
look is not my car i see every one saying twin cam. is a friends car not my ****.
Old Jan 3, 2010 | 11:10 AM
i have not seen the car in person he just told me about it hey says the clutch is good tranny make no noise.
Old Jan 3, 2010 | 11:12 AM
Domo_Arigato's Avatar
boost fixes all problems
Old Jan 3, 2010 | 11:15 AM
lol i dont think he want to do that. i will not waist my time with it lol
Old Jan 3, 2010 | 03:59 PM
so no one have a idea what can be wrong with my friend ef then
Old Jan 3, 2010 | 05:01 PM
~sp33~'s Avatar
EFB055
Check the timing, do a service (new plugs, oil, air filter, oil and fuel filters). I'm sure it will run better.
Old Jan 4, 2010 | 09:52 AM
crazyboy's Avatar
thats wierd cuz i have the stock dual point with an si tranny and it goes over 100 no problem. it takes a while but it gets there lol
Old Jan 4, 2010 | 10:43 AM
DCRB's Avatar
I'd like to ad to replace the cap and rotor, costs maybe 20-30 bux and is worth it imo.
has your friend done ANY mods to his b1? my guess is that like some are saying it may be tired out. i could see it struggling if it were starved for air or if the cat was partially plugged. also, has he removed the secondary butterfly, or upgraded the cam at all? from what i hear those things help... i mean, i can see a visual difference in an si cam vs. the stock b1 cam lobes...
Old Jan 4, 2010 | 08:42 PM
i dont know what he haves done to it i have not even seen the car. who know maybe he have everithing all F**k in there lol
Old Jan 5, 2010 | 07:32 AM
WhiteSTi's Avatar
Either tired motor, or it's a DX tranny and not actually an Si...
Old Jan 5, 2010 | 01:09 PM
dacrxguy's Avatar
dx and si transmissions are have the same gears just that the si has a different final drive not a huge difference
Old Jan 5, 2010 | 01:24 PM
Aaron0526's Avatar
IMO i think its because the 4 speed tranny has shorter gears and the 5 speed has longer gears needing more power. I have a 4 speed as well so thats just my guess.
Old Jan 5, 2010 | 01:31 PM
dacrxguy's Avatar
Originally Posted by Aaron0526
IMO i think its because the 4 speed tranny has longer gears and the 5 speed has shorter gears needing more power. I have a 4 speed as well so thats just my guess.
fixed
fixed op did they replace your freinds clucth what was replaced other than the transmission as wheel as maintenance stuff
Old Jan 6, 2010 | 12:38 AM
~sp33~'s Avatar
EFB055
Has anything been done to diagnose this yet?
tougel
12
Nov 26, 2009 09:23 PM
mrchevez
Dec 6, 2008 11:42 PM
stevew84
Mar 13, 2008 06:04 AM
Naturally_Aspired
Sep 14, 2005 11:57 AM
