crv rt4wd question
Old Jan 2, 2010 | 12:36 PM
Joe Vtec's Avatar
Default crv rt4wd question
um so i just got a 1999 crv i was thinking of turboing it but i don't want to give up the 4wd if i turbo it im gonna need to use a step down harness and a chipped obd1 ecu does the rt4wd run off the ecu cause i was looking around the sight and it seems like its just like an lsd tranny to all 4 wheels so i should be fine with changing the ecu right
Old Jan 2, 2010 | 05:56 PM
slomofo's Avatar
GDD Member
Default Re: crv rt4wd question
People have done AWD CRXs, Civics, and Integras before utilizing the CRV transmission and their own ECUs, so I don't think it's in your ECU.
Old Jan 3, 2010 | 06:17 AM
Joe Vtec's Avatar
yea so i should be good
Old Jan 3, 2010 | 03:41 PM
~sp33~'s Avatar
EFB055
The 4wd system is mechanically operated, not electronic. The more the front wheels slip, the more oil pressure builds and drive begins to be distributed to the rear wheels.
Old Jan 3, 2010 | 08:16 PM
Joe Vtec's Avatar
another thing will the drive shafts hold boost it won't break i mean they should b strong right
Old Jan 3, 2010 | 09:19 PM
~sp33~'s Avatar
EFB055
I dunno if you've ever watched a CRV launch before, but it seems to take at least a full revolution of the front wheels before there's enough oil pressure built up to transmit enough power to the rear to prevent the fronts from wheel spinning.
Based on that, i would say that there would be very little 'shock' (when you drop the clutch) being transmitted to the rear driveshafts causing them to break. If you plan on removing the clutch actuated part of the 4wd system, making it a true awd then i think that the rear driveshafts will need to be upgraded.
There was an Integra which used the CRV driveline in a rwd drift car, the only problem they encountered from my knowledge was axles breaking, and i don't think it was something that happened all the time.
All that being said, if you break them, upgrade them
Old Jan 7, 2010 | 07:14 PM
Joe Vtec's Avatar
thanks dude you've been alot of help
Old Jan 7, 2010 | 10:27 PM
~sp33~'s Avatar
EFB055
No problem'o good luck with it.
Aidroos
Honda CR-V & Element
Oct 7, 2017 03:48 PM
gnarly fbpem1
Feb 21, 2012 12:51 PM
LSEGHATCH
Jan 26, 2006 02:48 PM
vinuneuro
Jul 31, 2005 03:43 AM
94TealCivic
Acura NSX
Sep 10, 2003 05:27 PM
