Suspension & Brakes Theory, alignment, spring rates....
Trying to LIFT my EG.. any ideas?
Old Jan 2, 2010 | 10:45 AM
ThePizzaMan's Avatar
Default Trying to LIFT my EG.. any ideas?
Well, I've got a 93 Civic, and I'm trying to figure out if I can use a different spring to give me a lift.
I have new Tokico HP struts and shocks. I'm curious as to if I can use accord springs?
Going to rally in the desert with it. :p
Old Jan 2, 2010 | 12:26 PM
91tegrsjg's Avatar
Default Re: Trying to LIFT my EG.. any ideas?
get rid of the hps first off. they dont last long at all
Old Jan 2, 2010 | 12:29 PM
Wrong, They don't last long if you drop under 1.5".
I'm sticking with OEM height or a little higher if I can find a better spring.
Old Jan 2, 2010 | 08:29 PM
STOCK_SOHC_DX's Avatar
If you run stiffer spring rates than the shocks are valved for it will help blow those shocks faster as well.
Old Jan 4, 2010 | 04:02 PM
TunerN00b's Avatar
The easy button for a slight suspension lift, rubber coil spring spacers. (except you'll probably need tapered spacers instead of flat ones as shown for stock shocks)
Old Jan 4, 2010 | 04:17 PM
Jvs10's Avatar
Crv suspension should fit under it
Old Jan 4, 2010 | 04:40 PM
RC000E's Avatar
Try and find some bigger knuckles and drop the mounting points of the lower a-arms then fit a longer strut. It would take some research but that'd be a likely approach. Or keep your knucles and do custom tubular upper and lower arms with a longer strut/spring combo. Or for all fab, make custom upper and lower arms with a drop spacer for the strut/spring. The rear would be a little more complex but adapting something else may make things easier. Could be fun though.
Old Jan 5, 2010 | 12:25 PM
Tyson's Avatar
Spacers.
All you're going to be able to do is increase the amount of preload to reduce the sag (from fully extended to static ride height).
And those blues suck. Regardless of ride height, they will do a horrible job of controlling the suspension. You're going to want that even more with more use of shock travel.
blackeg
Suspension & Brakes
Sep 9, 2011 07:35 PM
Tim2179
Suspension & Brakes
Sep 4, 2010 08:44 PM
notsoslow
Suspension & Brakes
May 26, 2009 04:13 AM
WangChung
Jul 17, 2003 01:55 PM
