D series shift linkage pin work in B series trans ???
Old Jan 1, 2010 | 07:54 PM
35r'DHyBriD's Avatar
Default D series shift linkage pin work in B series trans ???
will a D series shift linkage pin aka bitch-pin work for a B series shift linkage or do i need to go and find a B series pin ? the reason i ask is that i put one in my linkage but the linkage moves around thru the car ...like if the car is in gear I can move the shifter like it is in Neutral this is making it diff. to go into 1st and 2nd alot of time i will hit 3rd trying to go into 1st and 4th trying to go into 2nd .... THANKS IN ADVANCED
Old Jan 1, 2010 | 08:05 PM
crx_si-r's Avatar
Default Re: D series shift linkage pin work in B series trans ???
i drilled out my shift linkage and just replaced the bitch pin with a bolt n nut.
Old Jan 1, 2010 | 08:12 PM
i think i will do that myself !! seems like a stronger option
Old Jan 1, 2010 | 08:15 PM
crx_si-r's Avatar
and easier. just unbolt instead of whacking at it with a hammer n punch. LOL
fatCRXguy's Avatar
Thats a good idea. I think im gonna do that too
Old Jan 1, 2010 | 08:16 PM
crx_si-r's Avatar
oh yea, i used 2 nuts on the the end to lock it in place. been holding strong for the last 4 years, untill 3 weeks ago when i swapped out my transmission.
Old Jan 1, 2010 | 08:18 PM
DONE AND DONE !! Nice idea
Old Jan 2, 2010 | 04:59 AM
beansandrice's Avatar
Bad idea.
5 dollar spring pin fellers.
Plus yo will most likely get a bit of "slop" on the shifter.
Old Jan 2, 2010 | 06:40 AM
EJ1_Sleeper's Avatar
ive always just used a bitch pin. easy to remove easy to install with the proper tool, or a 1/4 drive extension lol.
for the record, there the same size, but get worn out so its best to replace with a new one after 20 years.
Old Jan 2, 2010 | 06:52 AM
crx_si-r's Avatar
how do you get slop? when the bolt is the same size as the hole where the pin was? all i did was open up the hole on the shift linkage about 1/4 inch. like stated before ive been running it like this for the past 4yrs with no problems.
Old Jan 2, 2010 | 07:58 AM
Well, whatever works but its still a rig and not O.E.M.
Old Jan 2, 2010 | 03:06 PM
hatchet_honda's Avatar
very true....that bitch pin is a bitch for a reason..to fit sooper snug in there so theres no play in the linkage. how many times you really gonna drop your trans and have to remove the thing anyways?
Old Jan 3, 2010 | 12:21 PM
turbohatchBnuts's Avatar
BOOT lEG
Old Jan 3, 2010 | 12:24 PM
B series and D series pins are the same i used a integra pin on my sohc civic do it right dont use a nut and bolt thats boot leg
Old Jan 3, 2010 | 12:27 PM
SIred91's Avatar
Rainman
Its just fine if it fits tight. I use a grade 8 bolt and nylon lock nut. Works great.
Whats boot leg is all the Rota wheeled ricers running around with vAutozone parts all over their ****.
Old Jan 3, 2010 | 12:58 PM
I guess its what ever u preffer i think its boot leg to use a bolt and nut for ur shift linkage when u use nut and bolt ur gonna beat in and out and if u work on ur car alot motor swaps clutchs stuff like that u have to pull it out alot.This is why i wouldnt use a nut and bolt.The pin is made to fit in and act like a spring when in place nut and bolt is solid and if u beat in and out alot will make ur hole bigger in shift linkage so if u wanna keep getting bigger bolts everytime ur hole gets bigger than fine be boot leg i ll use a pin.
Old Jan 3, 2010 | 01:01 PM
SIred91's Avatar
Rainman
holy cow ^ LMAO
colombianchulo07
Northeast (Sales)
Jan 21, 2013 12:55 PM
01_CLtypeS
Free Stuff
Oct 4, 2012 07:48 PM
ITR EG
Northeast (Sales)
Jul 31, 2007 07:42 AM
-HONDA-
Mar 28, 2007 04:08 AM
Jdmbsixteen
Sep 2, 2003 09:57 PM
