Starter problems
Old Jan 1, 2010 | 01:19 PM
joexjoex44's Avatar
Icon6 Starter problems
car will not start. starter wont get signal. fuel pump turns on. tryed changing the clutch switch, not it. checked the fuses, not blown. some are not getting any juice, one of which is the starter relay fuse. any ideas?!?!
Old Jan 1, 2010 | 02:13 PM
EFPhilly's Avatar
Default Re: Starter problems
the wiring for the starter is easy. Just take the starter out and take it to the parts store. Have them test it, if its good, take a 9 volt battery and check for voltage at the other end.
Old Jan 1, 2010 | 02:56 PM
joexjoex44's Avatar
forgot to mention, the starter is brand new.
Old Jan 1, 2010 | 03:19 PM
Snap-off's Avatar
is it an aftermarket starter? sometimes the solenoid is bad, try tapping it with a pry bar and see if it turns on, but make sure you have power up to the starter solenoid first.
Old Jan 1, 2010 | 03:46 PM
S_F's Avatar
S_F
Jump the contacts on the solenoid with a big screw driver while someone turns the key. If it starts the solenoid is bad. Some times they are no good off the bat.
Old Jan 2, 2010 | 09:42 AM
joexjoex44's Avatar
starter solenoid is good. anymore ideas?
Old Jan 2, 2010 | 11:58 AM
Snap-off's Avatar
so you are getting power to your starter, the starter is engaging and disengaging, correct?
if so, then make sure you are getting fuel up to your fuel rail would be my next step, i mean there's not that many things, after fuel, make sure you have spark
Old Jan 2, 2010 | 12:11 PM
itsnotfast's Avatar
You don't need to have someone turning the key on. All you need to do is have the key in the onII position and jump 12 volts to the starter solenoid. If the starter turns, you have a signal problem and just trace the wire back until you find your problem.
Old Jan 2, 2010 | 05:10 PM
joexjoex44's Avatar
do u think the ignition switch might be bad? its weird, i checked some other fuses, for example my headlights, taillights, etc, its showing no juice going to them, but they still work? bad wiring?
Old Jan 2, 2010 | 06:03 PM
Snap-off's Avatar
if they work, then they have to have to have power going to them, cause they work. the ignition switch is a possibility, what kinda car, year and model?
Old Jan 2, 2010 | 10:00 PM
joexjoex44's Avatar
its a 92 civic hatch, not sure model. has a b16a obd1 SiR motor
slatermvp
Apr 13, 2012 07:54 PM
EKSedAndy
Mar 17, 2011 03:29 AM
pasenast
Apr 14, 2007 04:20 PM
KtHaNxBai
Jan 26, 2007 09:55 AM
integra_gsr98
May 24, 2005 11:23 AM
