Transmission & Drivetrain Gearboxes, Differentials, Clutches
vibration when on load..
Old Jan 1, 2010 | 10:01 AM
turbodailydan's Avatar
Default vibration when on load..
hey guys
i got this problem with my dc2 (itr turbo) im getting some serious vibration as soon as its on load, i thought the wheels were ganna fall off for a second .. (i checked wheel nuts lol..)
ive jacked it up and took a look around the suspension cant see anything obvious, checked wheels for play there is a little horizontal on the passengers side.
got a feeling its something to do with driveshaft/s but thought id see if i can get a heads up before i pull it apart tommorow morning
anyone point me in the right direction would be great help
dan
Old Jan 2, 2010 | 01:39 PM
boostinnc's Avatar
Default Re: vibration when on load..
i had this same kind of problem turned out to be a bad axle
Old Jan 3, 2010 | 12:10 AM
thanks mate i got ot sorted now it was the left side inner cv joint that was ****ed
Old Feb 12, 2010 | 05:48 PM
JDM-sol 89's Avatar
I have also had a similar problem; whenever i accelerate, my car shakes quite a bit inside. Both axle's have less than 3k on them and i just swapped trans for a mint trans that never hadsuch problems. The only last thing i can think of are bad mounts?
Old Feb 13, 2010 | 04:39 PM
morchaintlad's Avatar
New User
Does it feel like the vibration is coming from one side of the car more than the other?
Old Feb 14, 2010 | 08:03 PM
JDM-sol 89's Avatar
No, it just shakes a bit from about 2800 to 6000 rpms; mostly during the lower rpms/ lower end power is... Its a 94 gsr teg and I am not currently using either of my torque mounts so I'll probably just put those in and see how it goes. Thanks!
Old Mar 2, 2010 | 12:10 PM
fly_high_gsr's Avatar
its inside the tranny i had same issue differential
Old Mar 2, 2010 | 12:49 PM
JDM-sol 89's Avatar
actually turned out to be my suspesion?? i was running tokico blues with ebay coild, then got some k sports and it all went away..
kodylive
Sep 30, 2012 03:43 PM
BoltonGSR
Apr 3, 2009 06:15 AM
NYSItuner
Jul 5, 2008 08:06 PM
hybrid1990crx
Dec 20, 2006 10:10 PM
Hazzo
Jan 24, 2005 09:57 AM
