Benen strong bar
Old Sep 3, 2002 | 06:17 PM
Obee1.8's Avatar
Default Benen strong bar
Is anyone running this bar and what are your experiences with it?
Old Sep 3, 2002 | 06:31 PM
Reid's Avatar
Global Moderator
Default Re: Benen strong bar (Obee1.8)
Do they make one for the DC2?
Old Sep 3, 2002 | 07:08 PM
Chris's Avatar
ITR's have one from the factory.
Old Sep 3, 2002 | 07:17 PM
Reid's Avatar
Global Moderator
Default Re: Benen strong bar (Chris)
That's why I thought it was odd they'd make one for the ITR.
I thought the target audience for those bars are 92-95 Civics who have removed the rear bumper support.
Old Sep 3, 2002 | 07:39 PM
Rhetoric's Avatar
The strong bar and trunk brace are two different pieces.
When you remove the bumper support the holes that were once holding the bumper support in, are now used to bolt down the strong bar.
Two different pieces, probably for the same purposes though.
Old Sep 3, 2002 | 07:57 PM
Tommy_Gunns's Avatar
Default Re: Benen strong bar (G S R)
Someone should make aluminum pieces to replace the bumper supports on DC2.
If there is one, can someone send me a link or pic of it?
[Modified by Tommy_Gunns, 10:58 PM 9/3/2002]
Old Sep 3, 2002 | 11:02 PM
Obee1.8's Avatar
Correct,anyone using this? Experiences with it good,bad,ugly?
Old Sep 3, 2002 | 11:19 PM
Tony the Tiger's Avatar
Here's mine:
The strongbar is not the trunk bar on the ITR's. The BENEN Strongbar gives support during a rear-end collision so that you can safely remove the bumper support for weight reduction (-18 lbs). You can say that it also stiffens up the frame near the trunk because I had less chassis cracking noise after I installed the bar.
[Modified by Tony the Tiger, 11:44 AM 9/5/2002]
Old Sep 4, 2002 | 07:07 AM
Obee1.8's Avatar
Default Re: Benen strong bar (Tony the Tiger)
Old Sep 4, 2002 | 09:39 AM
Doctor CorteZ's Avatar
what did you buy Steve ???
ITR ??
Old Sep 4, 2002 | 10:25 AM
AK94GSR's Avatar
Default Re: Benen strong bar (Doctor CorteZ)
So if you get this strong bar for the trunk then you can safely take out the bumber support. How much does this cost?????
Old Sep 4, 2002 | 10:26 AM
DC2ITR's Avatar
Default Re: Benen strong bar (AK94GSR)
Old Sep 4, 2002 | 10:40 AM
acura_typer's Avatar
Banned
Here's mine:
You can safely remove the 18lbs of steel and install a 4lb piece of alum? No way. I would only remove the rear bumper if this is a DRAG car only. If you remove it, and get into a rear end collision, or even a side collision, the damage will be much worse vs if you leave the rear bumper on. Ohh, and the rear bumper is hidden incase you are wondering. The outside rubber/plastic part that everyone calls a bumper is just a 'bumper cover'.
its not safe to remove the rear bumper.
Old Sep 4, 2002 | 10:53 AM
KraZyCHOWMEIN's Avatar
Default Re: Benen strong bar (acura_typer)
agreed, save weight somewhere else instead of removing the vital safety measures that are put there for a reason
Old Sep 4, 2002 | 01:37 PM
The rear bumper support isn't as strong as you think... it's a piece of thin stamped steel that is good for a 5-10mph bash. During an accident, there is almost nothing to stop the car from crushing anyway... the trunk is supposed to crush so the driver won't get injured or killed from the G-forces. The bumper is there to minimize the repair costs from a minor accident. If you think it would save you from a severe rear-end collision, don't even think about it.
Old Sep 4, 2002 | 01:39 PM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
there is a reason Honda calls it the 5mph bumper. BTW I don't encourage taking it off and not replaceing it with anything.
Benen is bling, no more.
later
matt
Old Sep 4, 2002 | 01:43 PM
Banned
I think it offers more support than you think. It really doesn't do much to keep the trunk from crushing, rather keeping the rear frame rails together in a serious accident from the rear, and offering resistance in a side collision. You can take yours out if you wish, but don't say I didn't warn you.
Old Sep 4, 2002 | 01:46 PM
RTW DC2R's Avatar
are Benen and SSR the same company? also, do either one of them make lower rear control arms for the R? mine are tweaked and all fawked up.
Old Sep 4, 2002 | 01:59 PM
Default Re: Benen strong bar (champITR)
later
matt
Yep, I don't encourage running with no bumper... By looking at the construction of the Benen bar, I don't see how it would be weaker than the stock piece of stamped steel. Hold the bar in your hands and you will know why. The Benen bar is carved out of one solid block of aluminum, so there are absolutely no welds or joints served as weak points. It's placed on the same bolts as the stock bumper support, so it should reinforce the car in the same means as the stock bumper.
Old Sep 4, 2002 | 02:07 PM
xtrafastcivic's Avatar
Default Re: Benen strong bar (C5_ALLMOTOR)
you're driving a honda if you don't know if you get hit from the back no matter how hard with or without a bumper support you will get crinkles in the frame !!....
Old Sep 4, 2002 | 02:10 PM
Banned
Default Re: Benen strong bar (XtraFastCRX)
that was possibly the most confusing sentence, using sentence loosly, I have ever read. Could you use correct grammer so we can all understand?
Like I said, take out the bumper and see what happens in daily driving around a road course. You'll have a twisted rear sub frame. Ohh wait, not many of you even have a clue what a road course looks like. Drive on the street w/o the bumper is like asking for trouble. Take out the passanger seat if you want to save the 18lbs.
Old Sep 4, 2002 | 02:15 PM
SlapSmak's Avatar
that must be why, after a moron ran into the back of my GSR at a stoplight and hit the left rear bumper support, i only had to replace the cover and the ABS support member under the cover and there was no frame damage or other issues. the morons truck bumper was flattened. I love uneducated responses to posts from idiots.. it thrills me to read them.
Old Sep 4, 2002 | 02:37 PM
No, the Benen strongbar give the same reinforcement, if not, MORE reinforcement to the subframe. Possibly how could a spot welded piece of stamped steel give more reinforcement than the strong bar if you are talking about frame rigidity? Nobody here is taking off the bumper support and replace it with NOTHING. We are replacing it with the Benen strongbar.
Old Sep 4, 2002 | 03:35 PM
OT: tony what kind of ITB's did u get?
Old Sep 4, 2002 | 04:38 PM
BlueR1's Avatar
Default Re: Benen strong bar (KraZyCHOWMEIN)
I dont have the Benen strong bar but I just made my own out of alum. stock and got longer 12mm bolts. Works great, like a previous person said "less creeking sounds", but also seems to stiffen the back end a little.
