What stock sway bars will fit del Sol?
Old Dec 31, 2009 | 04:21 PM
targa del sol's Avatar
Default What stock sway bars will fit del Sol?
Hi all,
I have a stock '95 del Sol Si and can run any stock Honda sway bars on it in the racing series I'll be entering.What is a good Honda model to search out the stock bars to put on it?(something common to be found in a scrapyard,maybe Integra?)
Remember there is no rear bar on this model del Sol,so what else do I need for to install a factory style rear bar?
Old Dec 31, 2009 | 05:02 PM
delsolproblems's Avatar
Default Re: What stock sway bars will fit del Sol?
Del Sol VTEC sway bars. Use polyurethane pushings if they are allowed.
Old Dec 31, 2009 | 05:04 PM
BryanM.'s Avatar
Resident Gearhead
Not very common in salvage yards.
The Del Sol Si also has a rear sway bar IIRC. A little more common.
Old Dec 31, 2009 | 05:20 PM
No rear bar on the Si. Besides, for racing I'd expect him to get a new one. The bar itself is just 60$ at hondaautomotiveparts.com. You'll need the bar, two brackets, two end links, the bushings and maybe lower arms.
Old Jan 1, 2010 | 06:18 AM
Damn.....a new bar is gonna raise suspicions.....which will lead to closer inspection.....
No other models came with a factory bar?( such as a Civic Si? )
Old Jan 1, 2010 | 07:46 AM
delsolo95's Avatar
i put a Gsr rear sway bar from an Integra chassis on my 95 delsol Si. make sure you get it with the lower control arm too or get an aftermarket RLCA like skunk2 or blox to be cheap..hope that helps bro!
Old Jan 1, 2010 | 09:03 AM
If you want it to look original, by all means check out the salvage yards. If you can't find a used one, a little scuffing with a scotch brite pad and a little driving in the dirt will get rid of any semblance to newness.
Old Apr 2, 2010 | 05:37 PM
hondaphd's Avatar
TRIAL USER
will a del sol FRONT sway bar fit a 92-95 civic hatch??? easier to find del sol parts
supaman253
14
Jun 18, 2013 08:22 AM
povs9
Jul 6, 2007 01:59 PM
topher
Mar 27, 2002 06:40 AM
