car bogging on low rpms?????
Old Dec 31, 2009 | 03:42 PM
94LS_allmota's Avatar
Default car bogging on low rpms?????
so recently ive been driving my 95 gsr stock no internal work done to it......and its been running crappy like if it has a bad spark plug wire but i checked em and there good also there is a lil of water and oil inside the one of the spark plug wire where it plugs to the spark plug i cleaned it up and dried it and today again it manages to get soaked again...i also put silicone on the valve cover seals to seal perfect and sum how it still gets oil....
cliff notes
-oil or water like substance gets on one spark plug wire and boggs on every low rpm on each gear.. lmk what it can be........thnxxx and happy new year...
Old Dec 31, 2009 | 03:49 PM
DJYoshaBYD's Avatar
Default Re: car bogging on low rpms?????
bad seal?
bad head gasket?
pull off the valve cover again, and replace the gasket..
you maybe have a leaking valve seal?
i mean, your problem with it bogging could be that, but it could be the idle control system
Old Dec 31, 2009 | 06:37 PM
yea thnxx i think maybe head gasket maybe revving to 8k everyday caused a headlift and started leaking..but would it leak into the spark plugs and just one
Old Jan 1, 2010 | 12:50 AM
ttt
Old Jan 1, 2010 | 01:02 AM
94VTECoupe's Avatar
if it only happens at low RPM's then the spark plug wires/ignition isn't likely to be your problem. Usually ignition problems can be felt at any RPM. I would check your vacuum lines and make sure they're not leaking. Also your MAF? Is your car throwing a code?
potatointegra01
Apr 14, 2015 03:49 PM
koulninja
12
Aug 1, 2011 08:51 PM
Acura_DreamiN
Oct 26, 2010 07:23 PM
94LS_allmota
Jan 2, 2010 11:46 PM
tegdude227
Apr 27, 2006 10:14 AM
