differences between integra type r. .europe vs usa
hello people, the honda integra usdm, it is much various one from that European? why you have the b18c5? while here in Europe we have the b18c6? I put some photo of the eudm.
from we, the black seats recaro are of red and black single series on the itr, while those red ones are of single series on the white itr..
other difference?
other difference?
If you do a little research in the Type R threads you will find all the information you need. Or you can go to ITRregistry.org and look at all years, makes, models, and specs of all ITR chassis!
Here's a little work in progress that I need to add to. I have all the brochures I need to fill in the blanks, but need to find some time. It might answer some questions about the differences.
http://www.integratyper.org/specs/master_comparison.htm
Basically, the b18c6 is just a UK variation of the B18C5. If you want a side by side comparison, goto: http://www.integratyper.org/specs/master_comparison.htm
I only have the 2001 Canadian brochure. It says 8400 rpms for the Redline. The USDM brochures say 8400 rpms for the Redline and 8500 rpms for the fuel cutoff. Peak horsepower and torque are both below that. I'm pretty sure they are identical as they are both B18C5's.
8400 is the redline but I'm not sure about the fuel cut off being 8500. That sounds off to me. I'm positive I've had it revving higher than that. Almost to 9k.. unless the fuel cutoff is gradual.
That is just what the brochures and press information states. I don't know how fuel cutoff mechanically works.
Klutch_Wheels
Apr 30, 2014 02:13 PM
ClikHonda
Oct 22, 2009 07:46 PM
