Water in trunk. Sun roof drain?
Old Dec 30, 2009 | 09:26 PM
itsnotfast's Avatar
Default Water in trunk. Sun roof drain?
Car: 97 EJ8 coupe
Problem: Every time it rains or snows here my trunk gets water in it. I know its not the tail light gaskets because I just put new tails on and new gaskets. The problem was there before and after the change. I also don't think its the trunk gasket as it is dry just inside of the gasket all the way around. The water seems to come in the general area of the trunk hinges. The head liner is dry as is the back dash and back seat. Water comes in on both sides of the trunk but seems to come in more on the pass. side of the car.
My questions are where do the sunroof drains travel. Where do they exit the car. Are they just rubber hoses?
Pictures would be greatly appreciated.
Old Dec 30, 2009 | 10:22 PM
ReVeNgEd-SoN's Avatar
Default Re: Water in trunk. Sun roof drain?
I've had the same problem on my 97 civic. I've sealed everything and water still got into my trunk and had no idea what the problem was. Until...I found a SMALL little gap were the water was getting in were the trunk is...
When you open your trunk, look at the reservoir around it, were the water from the windshield goes when it comes down it. On the corners, you'll see a crack that goes down the middle of that reservoir on both right and left side were it was welded together. Water was leaking into my trunk from that little *** crack on both sides.. It wasn't a lot of water, but if you have a lot of water flow continuously down that it really builds up. Pour some water on both sides of the reservoir and look right underneath inside the trunk check for little drips of water.
I don't have a camera right now that works, or I would take pictures for you. I'm searching google now for a trunk picture lol too show you exactly what I mean.
EDIT: random picture edited
Old Dec 30, 2009 | 10:27 PM
itsnotfast's Avatar
Thanks alot man, i'll try this tomorrow. Hopefully the temperature gets above 30. What did you use to seal it?
Old Dec 30, 2009 | 10:28 PM
Just some clear silicone sealer. Or if you have a welder around, just re-weld that area.
Old Dec 30, 2009 | 10:31 PM
itsnotfast's Avatar
I have a welder and i'm capable but silicone sounds alot easier. Lol. Thanks again.
Old Dec 31, 2009 | 05:28 AM
94CivicSi's Avatar
I had the same little cracks develop on my '94 hatch. They're actually sealed, not welded, from the factory, which is why they crack. If you remove the tail lights, you'll see this "sealer" is just kind of brushed on where the panels meet.
I used a flexible sealant for windshields. Worked great, but had to be re-done in a few spots 2 or 3 years later.
About those sunroof drains though INF, the tube runs down the right side of the car and dumps behind the RR wheel through a "grommet/tube" that passes through the body. I also thought this was my problem after I found a bunch of old leaf parts and dirt clogging the exit. Might want to give it a look while you're messing around in the trunk.
Old Dec 31, 2009 | 05:33 AM
D Griff's Avatar
X3 on the trunk creases and silicone sealer as the fix. I used white caulk, it looks ugly, silicone would definitely be better.
Old Dec 31, 2009 | 05:58 AM
Matt93eg's Avatar
I am gonna look into this also. I get some water in my trunk when it rains. Not a whole lot but any amount is to much. I have some clear silicone so when I get my car back from body shop I will look into it.
Old Dec 31, 2009 | 06:05 AM
itsnotfast's Avatar
So today the temperature is warm enough to check this without it freezing and it fckn rains. FML
Old Dec 31, 2009 | 11:08 AM
Uh oh more water in the trunk now
94CivicSi: Your right it isn't welded lol. I was thinking about welding it and typed it like it was a welded joint haha.
Old Dec 31, 2009 | 11:26 AM
aznsquad's Avatar
yeah same thing happened to me, reweld
Old Dec 31, 2009 | 11:47 AM
cajuncharger's Avatar
Great info, I have the same problem, just a little water. I will check this out.
Old Dec 31, 2009 | 09:11 PM
itsnotfast's Avatar
As it turns out, this is definitely the problem. Couldn't fix it today due to rain and I didn't have enough time today to leave the car in the garage long enough for caulk to set.
Old Dec 31, 2009 | 10:13 PM
Glad I could help
Old Jan 1, 2010 | 01:45 AM
MYGODREPENT's Avatar
Anyone know if the seal for a '93 civic coup and 4 door are the same?
That might be a dumb question.
Old Jan 1, 2010 | 06:28 AM
kallar68's Avatar
i have the same issue on my 96 lx i'll be checking this later in the day. thanks
Prudz_lude
Feb 8, 2016 11:19 AM
foomashoo
Dec 12, 2004 03:48 PM
cdntegintx
Jun 24, 2004 07:45 PM
93si
Jan 4, 2004 12:20 AM
