how to remove civic door panel????
Old Sep 3, 2002 | 05:06 PM
1997exciv12w3's Avatar
Default how to remove civic door panel????
my drivers side pwerwindow came off track i think. How would i remove the door panel and would i jus put it bakon track once i take t of???
Old Sep 3, 2002 | 05:12 PM
Ricey McRicerton's Avatar
Default Re: how to remove civic door panel???? (1997exciv12w3)
This is for a non power anythign door, but here ya go. There is one screw in the door handle surround (dont know what it's called), one screw in the little cup about halfway down the door panel and there are 3 screws around the outside of the speaker. You'll also have to take out your speaker. Next you can either use a tool to pop out the little clips that hold on the door panel itslef of you can just pull...they're kind of stubborn, but they'll come off. I think you can just put the window back on the track once you get the door panel off, but you are going to have to remove the plastic sheet behind the door panel to get to it. Good luck!
jruiz094
Apr 4, 2010 04:59 PM
Nuts
Honda S2000
Aug 7, 2008 06:32 PM
Klutch
Honda Civic (2006 - 2015)
Feb 27, 2008 11:08 PM
todd.ludwig
May 1, 2006 02:27 AM
NtegraRacR05
Sep 15, 2003 06:57 PM
