ef9 si hard start
Old Dec 30, 2009 | 01:01 PM
EF927's Avatar
Default ef9 si hard start
my civic 90 si with a acura ls motor will not start right up when it is cold from sitting over night it just cranks and cranks for about 5 minutes then it starts up and the some times it does not start by the key i have to start it for the starter by jumping it from the battery to the starter in great need of help !!!!!!
Old Dec 30, 2009 | 04:28 PM
BrayzieEF9's Avatar
Default Re: ef9 si hard start
When's the last time you gave it a tune up?
Old Dec 30, 2009 | 05:05 PM
4drEF's Avatar
Keyboard Humorist
Since you have to run a power wire to the starter it seems that you should check all your ground and power connections.
If those are all good then I believe it's time to take the plastic off the steering column and get hold of a service manual to test your ignition switch.
PhilUp24
Aug 16, 2013 06:15 PM
vplukas101
Jan 25, 2013 04:09 AM
91tegrals
Feb 12, 2012 09:03 PM
coquieg6
Mar 3, 2010 10:22 AM
