FS: Integra GSR Oil Pump - 53k LS/VTEC
For sale is a used oil pump from a 2001 GSR -- $40 shipped anywhere in the U.S.
I did a full rebuild at 53k. Since everything was apart I chose to replace the oil pump. But i held on to the old one.
This is perfect for anyone doing a high mileage GSR rebuild on a budget or if you're building an LS/VTEC hybrid motor
below is a schematic of the oil pump and unfortunately i'm missing the relief valve, spring, and sealing bolt (# 5/6/7 in the schematic). I was going to replace them but chose to replace the whole pump instead
the 3 missing items can be replaced for about $12 from acura parts
OR an easier solution is to take the valve / spring / bolt from ANY 94-01 integra oil pump and swap them into this oil pump. I have carefully checked online (and you can too) to verify that the replacement parts numbers for the relief valve, spring, and bolt are IDENTICAL for all 94-01 motors. GSR, ITR, LS, GS, 2 door, 4 door, it doesn't matter. they all use the same part number. So any honda junkie or junkyard may have it lying around.
Feel free to ask any questions or make me an offer. I can post pics if necessary but basically its a gsr oil pump cleaned up and in good shape aside from the missing parts described above.
If you question if i'm legit you can check ebay feedback for 'djgurgla' 100% positive.
