want opinion and suggestions
Something that makes use of the stage 2 cams power band would be a good place to start.
If you know what that is it would help make things easier.
Without stating what the use of the car. power goals or the cams specs. It's hard to say weather you should go with 310cc injectors or 450s, a smaller 4-2-1 Tri-Y header or a big tube 4-1 header.
What size is your throttle body and have you done anything to upgrade the flow of air through the head other than adding a random stage 2 cam?
If you know what that is it would help make things easier.Without stating what the use of the car. power goals or the cams specs. It's hard to say weather you should go with 310cc injectors or 450s, a smaller 4-2-1 Tri-Y header or a big tube 4-1 header.
RaceCarRyne
Jan 14, 2006 07:14 AM
91integraLSVTEC
Sep 28, 2004 07:21 PM
ActiveAero
Jan 18, 2004 10:03 AM
