ARP head stud problem
Old Dec 29, 2009 | 11:18 PM
shytdoode's Avatar
Default ARP head stud problem
i got a new set of arp head studs and i put them in hand tight one of them is longer then the rest and i need a deep socket to put it in is that normal? or should it be in a different place?
Old Dec 29, 2009 | 11:34 PM
ballisticej1's Avatar
Default Re: ARP head stud problem
From what I remember, the stud that sits closest to the thermostat does stick up a little bit more than the rest, this is normal. Good luck
Old Dec 30, 2009 | 12:07 AM
shytdoode's Avatar
well this is for the one that goes to the top right hole
Old Dec 30, 2009 | 01:05 AM
shytdoode's Avatar
BUMP
Old Dec 30, 2009 | 09:54 AM
supra-n-civic's Avatar
move the long one to the hole nearest the thermostate hole. also make sure you are pretorquing the studs to the right psi before torquing the nuts on them.
Old Dec 30, 2009 | 02:27 PM
shytdoode's Avatar
Is that the only one tha needs 2 be in there specific place or do others need to be in certain spots? I only put them in hand tight like the instructions told me
Old Dec 30, 2009 | 05:52 PM
shytdoode's Avatar
bump
Old Dec 30, 2009 | 08:11 PM
shytdoode's Avatar
bump!!!!11
Old Jan 1, 2010 | 12:13 AM
shytdoode's Avatar
bump happy new years
Old Jan 1, 2010 | 05:02 PM
shytdoode's Avatar
Bump!!! Need to know where the tallest stud goes!!!
Old Jan 1, 2010 | 07:58 PM
thumper64's Avatar
The tallest stud goes closest to the thermostat. Take it out from where it is and move it. I'm amazed the instructions didn't say.
Old Jan 1, 2010 | 08:22 PM
i-VTEC_do_you's Avatar
not sure about different length but make sure you clean out the thread holes with air before installing them and good luck
Old Jan 1, 2010 | 09:56 PM
Corksil's Avatar
yeh wtf...
maybe there is a something down in the hole for the headstud. if I were you, I would remove them all and blow out the holes with electrical cleaner and compressed air. simple simple easy-peasey.
post up your solution, I may encounter el problemo in soon upcoming monfs.
A13sechatch
Mid-Atlantic (Sales)
Mar 7, 2011 08:14 AM
BoostedEgHatchFl
Dec 15, 2008 07:43 AM
DETALZ
Apr 13, 2007 09:19 PM
RED_90TEG
Apr 7, 2007 10:55 AM
Lmgrcivic
Jun 4, 2005 11:37 AM
