distributor cap problem..it pissing me off
Old Dec 29, 2009 | 10:00 PM
halocore's Avatar
Default distributor cap problem..it pissing me off
My gsr was running fine. so i took the distributor cap off and had a friend try his distributor cap on my car in which we ended up not to anyways. Now my car won't start. I'm thinking no spark. can anyone think of what happen.
we didn't even do anything to the car beside taking off the distributor cap. All spark wires are in it's place and it won't start. Could it be because i rub my finger on the rotor and touched the coil?
Old Dec 30, 2009 | 01:32 AM
mouab18c1's Avatar
Default Re: distributor cap problem..it pissing me off
wierd, but did you check for spark or are you just saying there's no spark cuz you havent checked yet?
Old Dec 30, 2009 | 06:15 AM
halocore's Avatar
There's no spark. It's probaly the distributer cap..i'll guess i'll have to replace it..
Old Dec 30, 2009 | 09:21 AM
DJYoshaBYD's Avatar
ok.. but did you ACTUALLY CHECK? like, did you pull the plug out and check for spark VISUALLY? or just listen, and say no spark?
yes, it is more than likely the cap, but you should check it first.. lol
Old Dec 30, 2009 | 02:23 PM
halocore's Avatar
Yeah i actually did check for spark. Did the old method where you stick a screw driver into one of the spark plug wires and hold it next to a ground. Still no spark...any ideas?
Old Dec 30, 2009 | 02:52 PM
DJYoshaBYD's Avatar
well, try the cap and rotor.. i mean, there is a chance that your ignitor or coil went out.. check those too.. you should be able to measure resistance on them to test.. bust out a manual, and test your dizzy..
also, check all your wire harness plugs lol
Old Jan 8, 2010 | 04:20 PM
halocore's Avatar
finally found out the problem, it was the ignition coil. I guess if you touch it without disconnecting the battery, it's a chance that you could shock it. hope this help anyone who's having ignition problem.
Noo_Ish_mee
Jun 27, 2016 02:44 PM
Nick Cronk
Apr 20, 2013 06:14 PM
crxion91
Jan 19, 2008 12:35 PM
ILOVEGIRLS
Apr 19, 2006 07:52 PM
chewiejdh
Feb 29, 2004 09:47 AM
