Will P215/45ZR17 wheels fit a '93 Del Sol?
Old Sep 3, 2002 | 04:19 PM
400HPdelsol's Avatar
Default Will P215/45ZR17 wheels fit a '93 Del Sol?
any remarks woould be great, i don't want to get flared fenders
Old Sep 3, 2002 | 04:38 PM
poison's Avatar
Default Re: Will P215/45ZR17 wheels fit a '93 Del Sol? (400HPdelsol)
if you are talking about stock rims, no they will not.
you would need to get your fenders rolled in or roll around 4x4 if you don't want to rub.
[Modified by poison, 6:39 PM 9/3/2002]
Old Sep 4, 2002 | 08:05 PM
90H22's Avatar
Default Re: Will P215/45ZR17 wheels fit a '93 Del Sol? (poison)
whalentires.com, Type in you car, pick some rims (noting the offset) and it will show you what tires fit. Wheel offset makes a big difference.
Old Sep 4, 2002 | 08:11 PM
mugenracer's Avatar
Default Re: Will P215/45ZR17 wheels fit a '93 Del Sol? (Two1Accord)
i dont think they'll go on, and if they do it'll make the car look like a crop sprayer or a cart, and the car will tram line like hell with that wide a tire. 205/40/17 would be a wiser bet
Old Sep 5, 2002 | 04:44 PM
RedRacer's Avatar
New User
I don't think those will fit. I have a del Sol and the 205/40's I have can rub from time to time. This is of course depending on how low you have your car. if you are looking for more contact patch....
I forget the name but somebody makes a 225/35/ZR17 that you might want to look into. The del Sol in the new SCC uses this size. not to mention he has them mounted on 7.5" wide rims. Offset is Crucial.
Old Sep 6, 2002 | 10:48 AM
rc1320's Avatar
Default Re: Will P215/45ZR17 wheels fit a '93 Del Sol? (RedRacer)
i had 215/45/16 that rubbed bad with barely dropped, i would think about a different size
Old Sep 6, 2002 | 10:49 AM
rc1320's Avatar
You have a 400 horsepower del sol????? Prove it
Old Sep 7, 2002 | 12:23 AM
hrc_385's Avatar
Default Re: Will P215/45ZR17 wheels fit a '93 Del Sol? (rc1320)
I plan to lower my Del Sol for 3 cm and put 205/45 R16 on it..
Will have problem?
Old Sep 7, 2002 | 02:31 PM
90H22's Avatar
Default Re: Will P215/45ZR17 wheels fit a '93 Del Sol? (hrc_385)
Who said they had 400 hp? I wanna see!
Old Sep 12, 2002 | 02:32 AM
stevecockrill's Avatar
Nope, you should be just fine with that set up. Of course the crucial issue is offset......
Steve
Old Sep 12, 2002 | 07:53 AM
CHEETAH's Avatar
I have 215/45 17 tires on my Enkei Shogun rims with Sprint lowering springs (lowers 2.5") in my 93 Del Sol ... good clearance.
Its not the tire size of 215 you should worry about, its the rim offset.
greg
streetcartuner
Feb 8, 2009 05:38 PM
techsynthesis
Jan 28, 2008 06:37 PM
2uce
18
Jul 4, 2006 07:54 PM
srg
May 22, 2006 03:40 PM
flippedoutasian
Oct 13, 2003 01:29 PM
