no Check Engine Light on with broken o2 sensor
Old Dec 29, 2009 | 03:31 PM
pedrolucas's Avatar
Default no Check Engine Light on with broken o2 sensor
Ok so here it is, I just broke my o2 sensor when I changed the gasket between the front pipe dans the headers. The car seems to run fine. I have no Check engine light on, But since a while, the car smells like gas. Could that be it ?
If not, well any clue about that ?
Spec: D15b jdm (OBD1) into 98 civic.
P.S. : I know that the check engine light works cause it came on when I'm starting the car.
Sorry for spelling.
Old Dec 30, 2009 | 07:38 AM
ChenLightning's Avatar
New User
Default Re: no Check Engine Light on with broken o2 sensor
@pedro
I would suggest replacing that broken O2 sensor. It can help the ECU in giving the right mixture of air and fuel. If not replaced, fuel consumption will increase. Hope this helps.
Old Dec 30, 2009 | 08:39 AM
sde780's Avatar
sometimes it doesn't throw a code, replace it anyways its making you run rich
Old Dec 30, 2009 | 11:21 AM
mrharmonic's Avatar
tru making you run rich bro its confusing the computer. also is the ecu chiped?
Old Dec 30, 2009 | 06:34 PM
pedrolucas's Avatar
I dont know if the ECU is chipped or not.
Do anybody knows a good website for cheap o2 sensor ? cause they are pretty expensive at my shop...
civicsaremean
Jun 24, 2007 08:27 AM
jarrYd
Mar 16, 2007 05:27 PM
JinDIESEL
Sep 17, 2004 06:33 AM
crxtreme27
Mar 26, 2003 07:04 AM
djtech
Feb 6, 2003 05:34 PM
