main relay and fuel pump trouble
Old Dec 29, 2009 | 12:35 PM
hatchz6's Avatar
New User
Default main relay and fuel pump trouble
hey guys new to honda tech i just got done doing a wire tuck on my 93 hatch. and i ran into a problem when i went to start it i have no power to the fuel pump.
I tried different main relays but still nothing. i got the pump to kick in after using a jumper wire on terminals 5 and 7 of the connector for the main relay like it said to do in the haynes book. I only extended the driver side wires in the engine bay that connect to the motor harness. i then ran those wires to the middle of the fire wall inside the car. those are the only wires cut and soldered. i then tested every wire i cut and soldered. and they were all perfect.
i did not cut or extend any of the motor harness just grouped all the connectors up and put the threw the fire wall.
I also checked all the fuses in both panels and they were all good.I also made sure all the connectors and grounds were all good also and they were.
any help would be great cause i running out of ideas Thanks!
Old Dec 29, 2009 | 12:46 PM
2point2's Avatar
Default Re: main relay and fuel pump trouble
ok, in short, you moved the ground wires from the thermostat housing to the firewall, correct?
Old Dec 29, 2009 | 01:07 PM
hatchz6's Avatar
New User
nope i left them on the thermostat why would i have to move them?
Old Dec 29, 2009 | 01:09 PM
hatchz6's Avatar
New User
i also changed ecus i case of a faulty one
Old Dec 29, 2009 | 01:58 PM
hatchz6's Avatar
New User
bump !anyone?
Old Dec 30, 2009 | 05:39 AM
hatchz6's Avatar
New User
bump
carlos8
11
Oct 31, 2013 08:32 PM
mr darcko
11
Jun 20, 2012 08:25 AM
f20cmx5
Feb 10, 2011 10:25 PM
lsboost3d3g
27
Apr 27, 2010 06:53 AM
Jago
Aug 2, 2007 02:21 PM
